Quote, originally posted by DGBibo » |
ok guys, because i love beating dead horses. i have a 2004 S60 2.5T 68K on the odo. i hear JWS 3309 is that Mobil 3309? or Mobil 1? where can i buy this stuff (JWS 3309 equivalent)? how many 14 quarts? anyone do the IPD flush? |
Quote, originally posted by fredmc » |
Manual transmissions use a true "synthetic" from Volvo. I don't know a sub for it. It's not JWS 3309. But if it's just one quart like you say, just get it from the dealer. |
Quote, originally posted by Turbos60 » |
Yes, your making it alot more confusing than it is though. |
Quote » |
Apply the parking brake, gear selector in park, start the engine and allow the engine to idle. Switch the engine off when 2 quarts of oil have been pumped out or when air bubbles become visible in the hose. Top up with 2 quarts of oil. repeat this procedure 7 times. Check the color of the oil, when the color of the oil is clear red (as new oil), switch off the engine and connect the return hose to the control system (valve body) cover. Check and adjust the oil level. |
