I just installed camber bushings and a poly bushing for where the rear trailing arm meets the subframe. Prior to, I could get the right rear toe to 0.0. Now the best it can do is 2.3 degrees. I assume the rear trailing arm is bent because I just replaced the toe link less than 2000 miles ago. So the part number on my current trailing arm is 30645608. The current part number I see in tasca is 30645610. The parts look different. Are they compatible? And were any improvements made if superseded?
Also, any other ideas of what could be throwing the toe off that bad on the right rear corner only? I want to get adjustable toe links and call it a day, but I would feel better replacing what's bent (and saving money) rather than band-aid fixing it.
Just get the ipd toe bars. I bet it's not much more if any than buying the arm.
From my electronic gismo- Galaxy S6
Is that the arm you are speaking of the toe adjustment arm or the actual arm the hub attached to at the bushing.
