1 - 1 of 1 Posts
I just had a Modulite trailer light harness installed on my 1999 V70 XC. It's available at etrailer (<A HREF="http://www.etrailer.com/pc-ELEE~119176.htm" TARGET="_blank">http://www.etrailer.com/pc-ELEE~119176.htm</A>). When I got home, I noticed there was no wire connected directly to the battery, so I did a little hunting and discovered that the installer tapped the battery line into a wire in the vicinity of the driver side tail light. As you can see in the photo (sorry, it's a bit blurry), the yellow wire and fuse from the Modulite connect to a thick gray and red wire that ends in some type of black plastic plug or terminal. Is this alright, or does it need to go directly to the battery? <p><IMG SRC="http://farm3.static.flickr.com/2526/3718271313_bd568994d6.jpg" BORDER="0">
1 - 1 of 1 Posts
