1 - 20 of 22 Posts
I'm used to RWD Volvos, so oversteering isn't a big deal to me.
But I'm not going to track the car. It's a daily driver for me.
I see most people have the Track Spec here, so I'm wondering if anyone has any experience with the neutral kit?
Re: Track Spec or Neutral Balance? (Body Massage)
Consensus is that the Neutral balance is a total waste of $$, and EVERYBODY with the track-spec LOVES them. They're not just for the track, either.
Re: Track Spec or Neutral Balance? (JoeLvo)
Quote, originally posted by JoeLvo »
Yeah, I was wondering about this as well. No track time for my V. So the thought here is to do both front and back and not bother with just one, right? What about the end links?
Re: Track Spec or Neutral Balance? (TWMn)
Quote, originally posted by TWMn »
IPD HD Swaybar Endlinks with Track Spec sways FTW!
Heh, I don't even have either products, but I've seen this topic enough times to save you some time waiting for everybody to post the above.
Track spec, the "neutral" bar is a waste of time
LOL, I guess we must be convincing.
Re: Installation time (Synesis)
3-4 hours and have them throw in the HD Endlinks at the same time at that point it wouldn't add any amount of time worth really charging. http://********************/smile/emthup.gif
Re: Installation time (kmg_S60R)
For a big improvement and less $$$ layout, you can get just the V70R neutral bar for the rear (25mm). It is the same size as the trac-spec S60R bar (25mm F & R). Nice improvement, even with just the front OEM bar left in (which is 23.5mm).
I did the job myself, took just over an hour and was well worth it. I can't justify the cash for a 1.5mm thicker bar up front and the time to drop the cross-member. Just didn't seem worth it.
Re: Installation time (jrgoffin)
IPD should just put together an R kit and sell it all the suspension and mounts together. .Wife does not like to see me with 13 things in a shopping cart, I might be able to get one big package though:)
Quote, originally posted by jrgoffin »
That's where it really makes the difference in steering response.
I got the trackspec bars front and rear, it really adds a nice touch to the R. It won't turn your R into a tail happy RWD car if that is what you are worried about, but it does allow some cool AWD power slides...
I just got the trackspec kit, QBM endlinks and strut bar conversion and the R feels a lot more stable. Quick lane changes are fun. No slop in the suspension on hard acceleration on on-ramps and off-ramps. This is what Volvo should have done in the first place.
Find a V70R owner who has switched over and buy their 25mm rear sway bar. I noticed a difference on the Nurburgring just doing that. Swapping front bar is much more involved from what I understand.
If you still want more, then go track spec. Just a thought...
Re: Installation time (Needsdecaf)
Quote, originally posted by Needsdecaf »
But yet the "neutral handling" rear bar that is only 1mm larger is frequently deemed a waste!
These FWD cars have lots of under-steer, and to minimize that, you need to stiffen the rear! Trust me, if you put just the 25mm bar on the back (V70R Neutral bar) there will be a noticeable improvement, and for a few hundred $$$$ less. But hey, it's only your money...
Quote, originally posted by "R" Kelly »
Don't these two posts contradict themselves? What is the OEM size of the rear sway? Is R Kelly referring to purchasing someone's OEM after they switched to IPD's? Sounds like that there is the opinion that just doing the rears will make a noticeable improvement and save $. How would those of you who have done both (at the same time) know anyway?
1 - 20 of 22 Posts
