My TPS keeps going off saying my front left tire has low pressure. Every time I check it, it's within normal range and when I reset the sensor, it stays quiet for a few days before going off again. Common problem??
What about other tires? Pump them to same pressure and recalibrate TPM status. Then see if it complains again.
TPMS doesn't run off tire pressure (no bladder on valve stem), it reads rotations via ABS system. You need to take in to dealer. They may see a fault code.
