They should fit in there just fine. If the standard Volvo ones dont fit, there are smaller aftermarket ones which transmit on the same frequency that you can usually get at any decent wheel/tire store. If you get new sensors they'll need to be reprogrammed to the car. VIDA isn't capable of this. You must use a handheld programming tool, however again, most tire shops will have the necessary handheld programming tool. If you reuse your same sensors, they will remain programmed to your car.
