1 - 1 of 53 Posts
Mine is an xc90 SPA; but in case the system behaves identically...
Had all 4 tires trigger low tire pressure. I checked all 4 were about 2 psi below the recommended 38psi pressure. I kept the engine running while running a compressor that is powered from the DC socket in the center console to inflate the 4 tires. I inflated it a little over the recommended pressure (maybe 1-2 psi). After finishing, I completed the calibration button presses and returned the vehicle to the garage. Seemed to work ok the day after; I don't think I checked in between. I didn't drive it other than the few meters it took to get (in reverse) from the driveway to the garage. I don't think that small amount of driving would have been sufficient if any kind of rolling data was needed for the process.
1 - 1 of 53 Posts
