1 - 11 of 11 Posts
i am wondering after changing everything else, where my power is gone on my 98 V70R AWD Manual shift, thats the reason why i have not drivem him so much. Aftern having some boosst problems above 1.5 shortly 2 bar seems that anything happened a year ago.
And i think this is the mess up, the camshaft times are totally wrong if the white markers describe the factury settings then one camshaft is wrong for about 10 teeths ? is this possible
If thats how they should be
Had the car for 3 years now, but made just 3.000km. So it seems that the belt on the first camshaft overjumped for about 8 teeth ? But i think this not happened in one event, i think it was to times the belt has to be jumped over. Will fix it as soon as possible and report. Have to look, perhaps a tensioner lost his power too. My car has also the hydraulic damper one Aisin btv-005. Is there a way to drive without them on shorter belt ? Some 850r i think did not have this hydraulical damper one or did they ?
car is idling "normal" , starting cold normal in a second. But when parked warm after hours the car starts after about 10seconds starting try, and adding some throtthle. Really weird that all.
Don't trust the white marks, it looks like whoever did the cam belt last marked it with the white marks at "12:00". See how there's a cut on the top of the cam cover on one side and a white mark on the other? I bet if you roll the engine back about half a crank those white marks will both point upwards, and you'll see the factory scratches on the gears line up like they're supposed to. They're just harder to see so a lot of guys make their own.
Yes i see, then i assume that the right camshaft from my photo is one tooth forward. Will check it out today after work
is there a way to check this besides the markings?
Some kind of light source blinking in the crankshaft part is used to see this, think it is called stroboscop
cams are standing same position all the time
I don't know what you mean. Here's an illustrated picture with more detail of what I was trying to say. Note the position of your cam bolts, they should match what I have in this picture, and in the second picture you posted. Your engine is not at TDC in your picture, which means those white marks are useless.
Here's a picture of the crank timing mark so you know if your crank is at TDC.
Hope this helps.
Service light is just a reminder to change the oil. Nothing to worry about.
is there a possibility to check the vacuum booster on properly working by connecting him on 12V ??
Volvo number 1390903
LloydDobler, your two photos have been a huge reassurance as I change the timing belt on my 96 855. The mark on my crank is different but everything else is identical. Thanks!
Glad to help. The 21st century is pretty awesome, digital camera, snap a picture, upload, worth a thousand words. :D
1 - 11 of 11 Posts
