1 - 9 of 9 Posts
I requested Total Toe to Zero and <br>had this done yesterday at Northway Tyres in Park Royal London,<br>engineer was unable to open the top bolt on the passenger front, I need <br>advise if it has been set up correctly cheers.<p><br><IMG SRC="http://i13.photobucket.com/albums/a268/danielswem/SKMBT_C35309081208550.jpg" BORDER="0"><p>
Re: Total Toe 0 (FRANCIS)
This is completely WRONG <IMG NAME="icon" SRC="http://www.vwvortex.com/zeroforum_graphics/screwy.gif" BORDER="0"> <br><B>You're supposed to run 0 toe IN THE REAR NOT THE FRONT</B><p>Take it back and do over or you will have poor front tire wear (and screwy handling) you will be wandering all over the place
I'm not confirming a damn thing, you go look it up.<br>The alignment is the same as any and all V70s but you substitute 0 <B>rear</B> toe for the OEM spec<U>.<br> <B> REAR</B></U> toe spec has changed 3 times over the years anyway..<p>I can't believe you would say to someone "set toe to 0" and not be specific! <IMG NAME="icon" SRC="http://www.vortexmediagroup.com/images/banghead.gif" BORDER="0"> <br>NO (street car) CAR runs 0 toe on the front (as far as I know), you would be wandering all over the place..<br>You want to play, try READING ENTIRE threads instead of taking one word out of context and using it
After setting it up correctly I took her on a 1000 miles weekend drive <br>london/france/lux/london, still hops on bends if I hit a pothole but generally a little better, but a little more rattles than prevously.
Get rid of the rear spacers and try that<br>I ran the same set up, (5 and 10mm spacers) looks great, but the farther out you put the rear wheels the more sidehop shows up!
1 - 9 of 9 Posts
