Torque s
Thread
Tightening torque (Nm)
M5
5
M6
10
M7
17
M8
24
M10
50
M12
80
M14
130
Exhaust system
(to the turbocharger (TC))
30 Nm
Cylinder head
Tighten the screws in sequence from the center and outwards.
Stage 1 20 Nm
Stage 2 60 Nm
Stage 3 angle-tighten 130°
Manifold
(cylinder head side)
25 Nm
Pipe screw
(coolant pipe I turbocharger (TC))
26 Nm
Pipe screw
(water heated crankcase ventilation.)
26 Nm
Pipe screw
(oil pressure line I engine block)
38 Nm
Sub-frame nut (lower torque rod)
65 Nm. Angle-tighten 600
Sub-frame screw
105 Nm. Angle-tighten 120°
Intake manifold
19 Nm
Catalytic converter
(to the exhaust system)
25 Nm
24 Nm
Knock sensor (KS)
20 Nm
Piston cooling valve
(piston cooling oil duct, in cylinder block)
36 Nm
Timing gear pulley
(camshafts without variable valve timing)
20 Nm
Timing gear pulley
(camshafts with variable valve timing)
10 Nm
Heated oxygen sensor (H025)
45 Nm
Carrier plate
Stage 1 45 Nm
Stage 2 angle-tighten 50°
Intermediate section
Stage 1 M10 20 Nm
Stage 2 M10 45 Nm
Stage 3 M8 24 Nm
Stage4M7 l7Nm
Stage 5 M10 angle-tighten 90°
Torque converter
50 Nm
Engine mounting Right side
(M10x35 to cylinder block)
(M8x23 to cylinder block)
Stage 1 35 Nm
Stage 2 angle-tighten 60°
Stage 1 20 Nm
Lower torque rod, transmission screw
35 Nm. Angle-tighten 40°
Lower torque rod, sub-frame nut
65 Nm. Angle-tighten 60°
Oil filter
(environmental filter)
25 Nm
Oiltrap
l5Nm
Oil pan plug
38 Nm
Oil pump
(countersunk Allen, M6x20, holds the pump housing together)
6 Nm
Oil return line
(turbocharger (TC))
12 Nm
Oil pressure switch
27 Nm
Stud
(at exhaust port, manifold, turbocharger (TC))
20Nm
Plug
(check hole for gauging valve clearance)
20Nm
Plug
(gauge hole I crankshaft seal)
38Nm
Belt tensioner (mechanical)
20 Nm
Flywheel
Stage 1 45 Nm
Stage 2 angle-tighten 65°
Vibration damper -2002 (flanged screws x4)
Stage 1 25 Nm
Stage 2 angle-tighten 30°
Vibration damper 2002- /flanged screws x4
Stage 1 25 Nm
(center nut)
180 Nm
Temperature sensor (coo Ia nt)
22 Nm
Timing cover,(front/rear)
12 Nm
Timing cover,(upper)
8 Nm
Turbocharger (TC)
(to manifold, without gasket)
25 Nm
Turbocharger (TC)
(to manifold, with gasket)
37 Nm
Spark plugs
30 Nm
Connecting rod cap (connecting rod with treated toothed surface between the connecting rod and cap, screw with waist)
Stage 1 20 Nm
Stage 2 angle-tighten 90°
Connecting rod cap (connecting rod with fracture surface between the connecting rod and cap, fully threaded screw)
Stage 1 30 Nm
Transmission screw (lower torque rod)
Variable valve timing center screw
120 Nm
Variable valve timing center plug
35 Nm
Ball joint - Spring strut, steel: 50Nm +- 12, 37 lb-ft 37 +- 9
Ball joint - Spring strut, aluminum: 40Nm =- 10, 30lb-ft +-9
Control Arm - Subframe L/R:
Stage 1 - 65Mn, 48 lb-ft.
Stage 2 - Angle Tightening 120degrees
Control Arm - Subframe:
Stage 1 - 105Nm, 78 lb-ft
Stage 2 - Angle Tightening90degrees
Front anti-roll bar to Subframe: 50Nm +- 12, 37lb-ft +-9
Rear anti-roll bar to Subframe: 80Nm +-20, 59lb-ft +-15
Lug Bolt Torque: 140Nm - 103 ft.-lb.
Strut brace
Brace to mount(one bolt) -- 58 ftlb 80NM
Mount to body(two bolts) -- 36ftlb 50Nm
Modified by p0cket penguins at 9:15 AM 10-1-2006
Modified by p0cket penguins at 8:51 PM 10-14-2006
Thread
M5
5
M6
10
M7
17
M8
24
M10
50
M12
80
M14
130
Exhaust system
30 Nm
Cylinder head
Stage 1 20 Nm
Stage 2 60 Nm
Manifold
25 Nm
Pipe screw
26 Nm
Pipe screw
26 Nm
Pipe screw
38 Nm
Sub-frame screw
Intake manifold
19 Nm
Catalytic converter
25 Nm
24 Nm
Knock sensor (KS)
20 Nm
36 Nm
Timing gear pulley
20 Nm
Timing gear pulley
10 Nm
45 Nm
Carrier plate
Stage 1 45 Nm
Stage 1 M10 20 Nm
Stage 2 M10 45 Nm
Stage 3 M8 24 Nm
Stage4M7 l7Nm
Torque converter
50 Nm
Stage 1 35 Nm
Stage 1 20 Nm
Oil filter
25 Nm
Oiltrap
l5Nm
Oil pan plug
38 Nm
Oil pump
6 Nm
Oil return line
(turbocharger (TC))
12 Nm
Oil pressure switch
27 Nm
Stud
20Nm
Plug
20Nm
Plug
38Nm
20 Nm
Flywheel
Stage 1 45 Nm
Stage 1 25 Nm
Stage 1 25 Nm
(center nut)
180 Nm
22 Nm
12 Nm
8 Nm
Turbocharger (TC)
25 Nm
Turbocharger (TC)
37 Nm
Spark plugs
30 Nm
Stage 1 20 Nm
Stage 1 30 Nm
120 Nm
35 Nm
Strut brace
