1 - 1 of 1 Posts
Does anyone here know the torque spec for the bolts that hold the bevel gear assembly together for a 2014 T6 AWD? Mine was leaking from where the case halves meet, so I took it apart and replaced the large O-Ring that's in there. The old one was so compressed that the end plate came off with very little resistance, and the new one seems to be made of a different material.
While VIDA has the torque specs for everything else I had to take apart, there's nothing listed for the case halves themselves. I knew this going into it and wasn't too worried about it, but once I opened it up I was surprised to see that the end plate holds one of the bearing races. I figure that should probably be torqued down properly. I did a lot of Google searching and found a ton of info on the P2 angle/bevel gear, but that's a completely different style case. Unfortunately the P3s are still new enough that not too many people have had to do much with these yet besides changing the gear oil or the end seals.
1 - 1 of 1 Posts
