Does anyone here know the proper torque setting for the upper engine bracket? Next week I am going to have the OEM rubber bushing poped out by a Arbor Press by a friend that has acess to a fabrication shop. I just wanted to know the torque setting that holds the bushing in and as well as the torque setting for the actual engine bracket bolts that holds the brcket in place. Thanks in advance. <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/smile.gif" BORDER="0">
Banned
Re: Torque Setting for Upper Engine Bracket? (bouncer)
Can you fellows pls order the technician pocket book?<br>It's updated each year so maybe ask you dealer for the former year so you've your entire car stated in it....goes for bolts torque to fluids to amount, from fuses and alternator spec to shocks and brake fluid and pad wear and disc and .......... everything is in it..... 1cm thick 10 by 5cm for the entire lineup s60 and s80 ym99 to and inclusive 2004 <br>No questions afterwards
