I connected the T plastic part to the vacuum hose.<p>When driving at ,the gauge shows 0,2-0,3.<p>When changing gears it raises up to 1,1.<p>What is the principle on turbo working system with the gauge?<p>Is it correst to connect the gauge to Vacuum hose.<p>According to my low informations,I see that the Boost gauge measures the vacuum amount?!!
Re: Today finished the gauges,need an explanation about the BOOST gauge... (xenophobic)
When you are reading negative numbers on the gauge, it indicates vacuum (when engine is idling, for instance)<br>As the turbo builds pressure (boost) you will see the gauge go up, around the 1.1 bar you see (which is maximum turbo pressure)<br>Sounds like you have it connected properly, although not sure which vacuum line you have tapped into. Some vacuum lines are more appropriate to splice into.
Re: Today finished the gauges,need an explanation about the BOOST gauge... (pino)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>pino</b> »</i></TD></TR><TR><TD CLASS="quote">, although not sure which vacuum line you have tapped into. Some vacuum lines are more appropriate to splice into.</TD></TR></TABLE><p><A HREF="http://imageshack.us" TARGET="_blank"><IMG SRC="http://img154.imageshack.us/img154/3825/e0to.jpg" BORDER="0"></A><p>There is a rectangular connection socket under this empty plastic cover.<br>There is a vacuum hose there.I connected to it.Is that true?
Courtesy of Johann:<br><IMG SRC="http://homepage.mac.com/jdijkstra/.Pictures/ext/vacuum.jpg" BORDER="0">
At idle, you should see -0.5 to -0.7 bar.<p>While cruising, it can be anything between -0.2 to +0.5 bar.<p>While accelerating, between 0 to 1.1 bar.<p>Try connecting the T where pino indicated.
