So my transmission, I believe, is at the end of it's life, or at least the linkage.
I have an M400, I think, four-speed with no overdrive.
At the moment, the shift lever will only go in the first and second position, and when releasing the clutch, they give the impression of being third and fourth gear. the transition for the third and fourth gears in the shift pattern isn't detectable at all so I assume at least a shift fork is trashed.
Anyways, I'd like to rebuild it, but I figure some of you might know a little bit about it.
Are the parts available? Are they going to cost so much it would be stupid?
Financially am I better off going with a used transmission crap shoot?
I'm not even sure what my options are at the moment, enlighten me, if you'd be so kind.
