1 - 13 of 13 Posts
A quick question for those who have tackled the collar gear themselves.
Which is a safer, easier way to get a grip on the collar gear. Is it better to grind two big grooves, or try three holes 120 degrees apart?
Or say F)*K it and call in professionals and let a shop do it?
Any thoughts?
I say grind as well.
I HATE drilling into hardened stuff. Lots of chance for slipping off with the drill while trying to get it to start.
Just use an air hammer. It's worked for me every time.
Sounds like a great way to trash the diff bearing. I would rather advise people to use a puller so the forces are applied to the shaft and collar instead of beating the **** out of their transmissions.
I found it surprisingly easy to drill through the oem collar if thats the route you decide to go. I was able to use the same cheap metal bit the drill 3 holes. I was expecting it ro be a pain, but it went fairly well. I put some bolts through the holes and used a 5 ton puller. I fought it for an hour or so before deciding to take a break. I left the puller attached to the collar under load over night and it slid right off the next morning. Guessing I got lucky considering the horror stories I have read on here. Haha.
Sent from my SM-N910P using Tapatalk
Grind 3 slots for a puller and use an oxygen actatlyne torch to pop that epoxy
I broke a puller with out using heat first
I drilled 2 holes and then used a 2 jaw snap on puller and some heat.
Like Astro-R said it drills very easily, only slightly harder than aluminum
I now use the old collar as a paper weight at work
Discussion Starter · #13 ·
PRO TIP: if you want to un-fasten something that’s “stuck” with Loctite, or other adhesive fastener additives, use the ‘creep-fail’ approach. Load up the tool with a constant torque, below the threshold that will strip the fastener, be patient…the thread-locker will ‘creep’ and eventually release within 10-60 sec. Higher strength stuff takes more time but still works...
1 - 13 of 13 Posts
