1 - 2 of 2 Posts
I have the TME springs installed on my V and over medium size bumps only the rear will bottom out and make a loud thud. Has anyone else had this problem? Has anyone cut the bump stops to fix the problem?<br>DAn
Re: TME springs and rear bottoming over bumps (Ride R)
Have you had the springs installed for very long? I know, only from this forum, that there has been the occasional noisy rear spring onloy with the V's. <p>It has, to the best of my knowledge, been isolated to an incorrect shipment or incorrect install. I know if you have the correct part and correct install you won't hear anything other than the normal noise associated with 4C. Perhaps a rabbit ear? Or is this a serious noise that you are hearing with your springs?
1 - 2 of 2 Posts
