hello, I'm looking for low profile tires that will fit 19×8.5 rims. Mind you the car is lowered on H&R springs. Just need information about what would work (with/without wheel spacers) and what will cause rubbing. Thank you.
What offset are you running I have 18x8.5 wheels with a +40 offset and my tires actually poke out past the fender slightly
Sent from my SM-G965U using Tapatalk
yeah It's +40
Sent from my SM-G950U using Tapatalk
I'm running 245/35 18 so I'd stick with either a 35 or even a 30 sidewall and you should be good
245/40/19 work just fine.
35 or 30 sidewall on a 19 is crazy. Polestars run 245/35/20 so there is no need to run 35 on 19s. Stick with 40 to give you more cushion/protection.
