I went on vacation, and had to drive of some rough roads, and set off all tire warning lights all turn yellow and dash warning light, no flats, I checked the tire pressure all normal and re calibrated and all is normal.
They all might be just on the threshold of being low and happened to cross that threshold then. Tire pressure needs to be readjusted over time in general.
Thank you, I did recheck the cold pressure this morning, left rear was 2lb pounds over 35 and right front and rear pressure was 34 lbs re adjusted and going for a drive to re calibrate. again thank you.
