1 - 6 of 6 Posts
Ok so i got a deal i could not say no to on a set of tires ... Great but ... I have no idea if they will fit i got told yes from one person no from another and it might from someone else so ....
Im running 205/50/17
and i bought 235/45/17 tires will they fit ?
How wide are your rims, if they are 17x8 or 17x8.5 it should be fine. one thing that will change for sure is your speedometer will be off since you changed the width of the tire without changing the size of the rim
Re: Tire size help (jdsr917)
Quote, originally posted by jdsr917 »
If you have 7.5" wide rims then the new tires should fit, although I wouldn't go wider than 225 on 7.5" . If you have 8" or wider rims then you should have no problems at all.
About the speedometer, you had approx. 25.07" of wheel/tire diameter. With the new tires you'll have approx. 25.33" of wheel/tire diameter. That should make the speedometer read a couple mph less than you're actually going. The difference should not be too big, though.
Thanks guys im pretty sure im running 7x7.5 they are optional from volvo liik like pegs without the R on them ... The price was just WAY to good to pass up.... I hope they fit since im lowered !?
1 - 6 of 6 Posts
