1 - 8 of 8 Posts
I just checked all 4 tires and pressure is 42PSI
I never changed the pressure since new 2 month ago.
Is this normal pressure or I should bring it down to 38psi
running scorpions on 21" wheels
Do you have a T8? If yes, then 42 psi is officially what is recommended at least for 20” and 22” which I run.
I have read in other threads that non-T8’s are running 38 psi, but hopefully others will comment. Otherwise, look at tire label on the driver’s side door jam B pillar.
T6's are 38 PSI front and rear, assuming stock tire/wheel size.
Make sure you check tire pressure with tires cold.
1 - 8 of 8 Posts
