1 - 6 of 6 Posts
Hi there,
has anyone here installed the 3RD EYE Tire Pressure Monitoring System (TPMS)?
If yes I have a few questions:
1. how do you take off the A pillar trim to get to the wire harness and route your TPMS harness? I understand there is an airbag too.
2. to which harness/fuses have you connected the TPMS harness?
Thanks,
Re: Tire monitoring system install (doru)
Quote, originally posted by doru »
Hi there,
Thanks,
I don't have the diagrams around, but you pull at the upper edge, and after it pops off there will be another retention clip. There are two types, depending on chassis number I guess, and on mine you had to rotate the clip. Then the bottom just slips out. Reverse to replace. The airbag part is just rolled up in that space, the actual charge isn't in the a-pillar. I hooked the system up to the accessory (cig lighter) fuse. There's enough cable to put the display anywhere you want really. I find that it looks best just to the right of the rear view mirror in the black sunshade section. It fits perfectly there. A little hard to get to the buttons, but how often do you press them anyway?
Re: Tire monitoring system install (partridge)
Quote, originally posted by partridge »
Nice install!
OT - May I suggest that you run the car seat tether under the rear headrest and not over it - it willl eliminate unnecessary play should hte device need to be used. http://********************/smile/emthup.gif
Re: Tire monitoring system install (bschurr)
Quote, originally posted by bschurr »
Nice install!
I've tried everything to get it under. Nothing seems to work. Next time I move it I'll give it another shot.
I love those blacked out sections around the RVM, great for hiding electronic doo dads like iPass transponders, radar detectors etc.. I see BMWs etc driving around with that stuff visible and it really clutters up the look.
1 - 6 of 6 Posts
