Just switched to new wheels and tires for winter (19" Nokian Haka R2). Summer set is the 20" which I believe run at 39 psi (!! not 32!)
Would I run the winter 19's at 39 psi as well?
that seems like a really high pressure compared to other cars I have had!
Just picked up a new XC90 and my psi says 42 all around. Might be why my ride seems a little stiffer than I'm used to. I figured once it went down a little it might soften up.
look at the sticker when you open the driver side door that is your correct tire pressure. The manual also has it. Psi is 38 psi cold tires
