Discussion Starter #1
I'm thinking of doing my timing belt, I see there are different kits. I understand its a good idea to change the water pump since your in there, but some kits have front and rear cam seals. Do they need to be changed when replacing the timing belt? Or only if leaking? Also the R has about 50,000 miles but the belt is 8 years old, I know I'm good on the milage, but does age play a factor in replacing the belt?
8 years is the max that you should go time wise and if the cam seals aren't leaking I would leave them alone.
Discussion Starter #3
Thanks, timing belt is now on the list
I'm in the same boat, i'm at 103k and some change now, i'm about to pick up a belt kit and give it the ol' college try. I'm up in the air about needing the cam locking tool.
