I am going to be getting the timing belt done soon and was wondering should I do all this,<p><A HREF="http://www.fcpgroton.com/product-exec/product_id/26204/nm/Volvo_850_Turbo_Timing_Belt_and_Water_Pump_Kit_/category_id/201" TARGET="_blank">http://www.fcpgroton.com/produ...d/201</A><p>or just replace, Water Pump, Timing Belt, Timing Belt Tensioner, Timing Belt Idler Pulley, and Serpentine Belt? <p>Besides leaks at what point or are all the seals ready to be done?
Re: timing belt? (maronha)
You are fine with a timing belt, water pump, tensioner, idler pulley, tensioner pulley, and serpentine belt...unless you have leaks. Visible oil leaks, consider installing some of the additional seals contained in the kit.<br>Be forewarned, one of the additional seals contained in the kit is to be used in a 12 - 14 hour project which includes dropping the sub-frame and separating the transmission from the block.
Banned
We give you all the seal in case you need them. I would replace the seals on the timing belt side while you are in there. As for the other side, just do them if they are needed.
