I have 1990 240 DL SW M47 . There is a sticker on fan shroud whith a picture of timing belt and "Byte Exchange ,Cambio,Austausch etc ) and 149 K written over it . So I assumed that at 149 K belt was exchanged . Now I am at 202K and am in a dilemma to change it or not . How important is to change the three seals and the tensioner. If I do not see any oil in the timing belt area them can I leave the seals . What about the tensioner .
Second I want to ask is the source of these components . Belt at volvo dealer is 25 $(still OK) but the seals are 16 $each and tensioner is 102$. .Which are another good source of belts . I was thinking about getting seals from fcpgrotten But then again if they are good do I need to risk with a non OEM part.
Last Question I want to ask is technique of restraining the harmonic balancer to loosen the crankshaft bolt. Lots of techniques are mentioned in FAQ and then there is $50 tool . Which tech can be safely applied to this model year car with manual transmission . 4th gear and e brake tech has been suggested but I wanted to get another openion before starting .
Thanks in advance
Regards
Gopesh
Thanks in advance
Regards
Gopesh
