1 - 20 of 23 Posts
Anyone replace their timing belt? <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/confused.gif" BORDER="0"> <p>Need an FAQ, Sites, Special Tools to buy, etc. <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/embeer.gif" BORDER="0"> <p>
Re: TIMING BELT REPLACEMENT (wrodri54)
Here's a good starting point.<p><A HREF="http://www.babcox.com/editorial/ic/ic60326.htm" TARGET="_blank">http://www.babcox.com/editorial/ic/ic60326.htm</A><p>I'm going to do this in the next two weeks, and the biggest problem is getting the belt off around the crank pulley. I've read that there is a housing below the crank pulley, and it has 2 10mm bolts that can be removed and the bracket moves and then you can get the belt around the pulley without removing it. Removing the pulley takes a 30mm socket, and almost certainly an impact wrench. Have wrench, but not enough air pressure or volume to accomplish the task. That's why I looked for ways to get the belt around the pulley without removing the pulley.
Re: TIMING BELT REPLACEMENT (wizzard_al)
It's really not that expensive to have done (compared to a 6 cyl Audi/VW). By the time you buy all the special tools you'll need you should just find a good independent shop and let them do it. You'll also kick yourself if you make even a small mistake -- your engine (and wallet) depend upon it <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/eek.gif" BORDER="0">
Do it right or have someone else do it
have a pro do it....its not a do-it-yourself item <IMG NAME="icon" SRC="http://www.vortexmediagroup.com/images/banghead.gif" BORDER="0">
I did it on my s80 about a month ago, I HIGHLY suggest you bring it to your dealer.
not to be rude...but if you are asking about it, you should probably leave it up to a volvo mechanic, or the dealer. <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/smile.gif" BORDER="0"><p>its a non-forgiving repair job.
Re: TIMING BELT REPLACEMENT (Freeworld)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>Freeworld</b> »</i></TD></TR><TR><TD CLASS="quote">It's really not that expensive to have done (compared to a 6 cyl Audi/VW). By the time you buy all the special tools you'll need you should just find a good independent shop and let them do it. You'll also kick yourself if you make even a small mistake -- your engine (and wallet) depend upon it <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/eek.gif" BORDER="0"> </TD></TR></TABLE><p>true.<p>interference valves, which we have, are not something to PLAY with.
Re: (Copeland)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>Copeland</b> »</i></TD></TR><TR><TD CLASS="quote">I paid something like 800 or less for mine. Ill see if I can find my reciept.</TD></TR></TABLE><p>expect $400-$600 for S60.
Timing Belt, Oil Change, and New Front Brake pads (just the pads not the install)<p><b>$705.00</b> NOT BAD AT ALL <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/eek.gif" BORDER="0"><p>Labor- $390.37<br>Parts- $276.80<br>Misc. Charges $15.57
705.00- $114.00 for the pads and oil change<p>=<b>$591.00</b><p>So, Phuz was right expect around 600.00
autoweb actually states $415 for the repair (T&M) but I have found that they underestimate a little bit sometimes.
Discussion Starter · #15 ·
Re: (phuz)
Thanks for the advice guys <IMG NAME="icon" SRC="http://********************/smile/emthup.gif" BORDER="0">
Re: (wrodri54)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>wrodri54</b> »</i></TD></TR><TR><TD CLASS="quote">Thanks for the advice guys <IMG NAME="icon" SRC="http://********************/smile/emthup.gif" BORDER="0"> </TD></TR></TABLE><p>anytime. let me know how much you get charged if you decide to take it somewhere <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/biggrin.gif" BORDER="0">
Re: (phuz)
The formula goes like this... 1st tooth off is free. every tooth after that is $1000.00 <IMG NAME="icon" SRC="http://www.vortexmediagroup.com/images/banghead.gif" BORDER="0">
I replaced mine about 3 months ago in my home garage. It took 2-3 hours but there wasn't anything particularly difficult about it. I am not a master mechanic or anything, but I have changed timing belts on other cars. By comparison the S60 seemed pretty easy. I DO have an impact wrench and socket that fits, though. That took care of the hardest part.<p>About a month ago I changed the water pump and timing belt on a Lexus SC400 V-8. THAT WAS AWFUL. <IMG NAME="icon" SRC="http://www.vortexmediagroup.com/images/banghead.gif" BORDER="0">
Re: TIMING BELT REPLACEMENT (Tim G)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>Tim G</b> »</i></TD></TR><TR><TD CLASS="quote">I replaced mine about 3 months ago in my home garage. It took 2-3 hours but there wasn't anything particularly difficult about it. I am not a master mechanic or anything, but I have changed timing belts on other cars. By comparison the S60 seemed pretty easy. I DO have an impact wrench and socket that fits, though. That took care of the hardest part.<p>About a month ago I changed the water pump and timing belt on a Lexus SC400 V-8. THAT WAS AWFUL. <IMG NAME="icon" SRC="http://www.vortexmediagroup.com/images/banghead.gif" BORDER="0"> </TD></TR></TABLE><p>confidence and patience. <IMG NAME="icon" SRC="http://********************/smile/emthup.gif" BORDER="0">
1 - 20 of 23 Posts
