<br>I was just informed by my dealer that my car has a 120K mile timing belt replacement interval while some other models of S40 have a 105K mile timing belt replacement interval. Anyone know why there's a difference?<br>
Re: Timing Belt Replacement (Seitch)
Not sure but that is true. It depends on the year...
Re: Timing Belt Replacement (ForceFed Motorsports)
And on the engine type. The California-spec engines (shipped in many other states) have a longer service interval.<p>Tom.
If You have Kept Your Coolant Clean and Changed which Adds Yrs. to<br> the Water Pump - - which Fails and that Tears the Belts - If You have been doing a lot of Long Distance Driving - Not a Lot of Short Interval -Runs<p><br>You could likely go to 135,000 before changing , I have also seen a lot of the older style v70 and v90 go to 150,000 before changing . If You see a Little Drop of Water on the Ground and the Drip looks like Its coming from the Water Pump , Change Immediately . <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/embeer.gif" BORDER="0">
