1 - 6 of 6 Posts
2005 S60 R
Getting ready to replace timing belt, need some specs.
Where is the tensioner supposed to be oriented when replaced and tensioned?
Is there a list of torque specs?
Doing this tonight, quick help is appreciated.
Also, put the car in gear on stands and checked the AWD. Was planning to replace all fluids, but the rear wheels did not turn on the stands. Does this mean there's no AWD? any way to be sure while its in the air?
Here's a pic from when I did my TB. Hope this helps.
Thanks, I got it done, it wasn't that bad.
Found out I don't have AWD at this point, not sure if I'll fix it or not.
Still need to replace driveline oils and subframe bushings, but I'll save that for next weekend.
Sent from my iPhone
Not a bad job at all, just a tight space to work in.
1 - 6 of 6 Posts
