1 - 20 of 26 Posts
Hey,<p>Its time for me to replace the rotors on my R. I would appreciate any suggestions on where to get new rotors at a good price. They don't have to be OEM and I need to get front and rear. <p>Thanks!
Re: Time for new Rotors. (12188s60)
Try John @ BVV:<p><A HREF="http://forums.swedespeed.com/zerouser?cmd=viewprofile&id=14580" TARGET="_blank">http://forums.swedespeed.com/z...14580</A><p>Or Ipd:<p><A HREF="http://www.ipdusa.com" TARGET="_blank">http://www.ipdusa.com</A>/
Re: Time for new Rotors. (MagoonR)
Or ViVA,<br><A HREF="http://www.vivaperformance.com/catalog/product_info.php?cPath=81_94&products_id=804" TARGET="_blank">http://www.vivaperformance.com...d=804</A><p>IPD's rotors are good. I just put on a pair a few weeks ago. Cheap and good quality.
Re: Time for new Rotors. (mad matt)
Just a bit more than OEM, but worth it.<p><A HREF="http://www.drt-sport.com/bigcell.php?i=878" TARGET="_blank">http://www.drt-sport.com/bigcell.php?i=878</A><p>
Re: Time for new Rotors. (jrgoffin)
or Rock Auto<p> <A HREF="http://www.rockauto.com" TARGET="_blank">http://www.rockauto.com</A>
Tasca Volvo, less than $100 apiece. <IMG NAME="icon" SRC="http://********************/smile/emthup.gif" BORDER="0">
Dont waste your time with the Volvo ones .... <p>IPD ones are much much nicer and cheaper <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/biggrin.gif" BORDER="0"> <p>volvos rotors have a unfinshed surface on them so they really tear up your brake pads the first few times you use them. <p>The IPD ones have a finished mahcined face. <br>and made to volvo specs also. <p>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>jrgoffin</b> »</i></TD></TR><TR><TD CLASS="quote">Just a bit more than OEM, but worth it.<p><A HREF="http://www.drt-sport.com/bigcell.php?i=878" TARGET="_blank">http://www.drt-sport.com/bigcell.php?i=878</A></TD></TR></TABLE><p>I have the drill/slotted rotors from them. So far pretty happy. Had them for about 15,000K now. <IMG NAME="icon" SRC="http://********************/smile/emthup.gif" BORDER="0">
How easy is it to remove the rotor? I have to remove my right rear rotor today.
Take off the wheel<br>Unbolt 2 bolts holding the caliper<br>Secure the caliper so it doesnt hang<br>Unscrew 10mm bolt<br>Slam the rotor with some rubber hammer and ur good to go
Re: (s140s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>s140s</b> »</i></TD></TR><TR><TD CLASS="quote">Take off the wheel<br>Unbolt 2 bolts holding the caliper<br>Secure the caliper so it doesnt hang<br>Unscrew 10mm bolt<br>Slam the rotor with some rubber hammer and ur good to go</TD></TR></TABLE><p>Do I just hit it in board or outboard? Or do I just swing away? <p>I removed the big bolt in the middle and the small bolt, should I put the big bolt back on?<p><IMG SRC="http://i723.photobucket.com/albums/ww237/sinisin63/IMG_0981.jpg" BORDER="0">
Re: (sinisin63)
Put the big bolt back you only need to remove the small one at 5-6 oclock in the pic.
Re: (sinisin63)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>sinisin63</b> »</i></TD></TR><TR><TD CLASS="quote"><p>Do I just hit it in board or outboard? Or do I just swing away? <p>I removed the big bolt in the middle and the small bolt, should I put the big bolt back on?<br></TD></TR></TABLE><p>1. Take the caliper out - two bolts holding it, look behind it.<br>2. Take out the small bolt holding the caliper, IIRC it's a 10mm or so, you can't miss it, it's right there in front (where the wheel would cover it).<br>3. Bang the caliper until it breaks loose, inboard/outboard/whatever it takes.
No one make a vented rear, you should stick with the OEM rotor for the rear.
Re: (Chilled Man)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>Chilled Man</b> »</i></TD></TR><TR><TD CLASS="quote"><p>volvos rotors have a unfinshed surface on them so they really tear up your brake pads the first few times you use them. <p></TD></TR></TABLE><br>Bull shi*<br>I've had nothing but good luck with Volvo rotors for thousands and thousands of miles.
Re: (Chilled Man)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>Chilled Man</b> »</i></TD></TR><TR><TD CLASS="quote"><p>volvos rotors have a unfinshed surface on them so they really tear up your brake pads the first few times you use them. <p></TD></TR></TABLE><br>Bull shi*<br>I've had nothing but good luck with Volvo rotors for thousands and thousands of miles.<br>
Re: (JRL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>JRL</b> »</i></TD></TR><TR><TD CLASS="quote"><br>Bull shi*<br>I've had nothing but good luck with Volvo rotors for thousands and thousands of miles.<br></TD></TR></TABLE><p>They suck dick compared to the IPD ones <p>I have both sets and will never buy another set of volvo ones <p>IPD FTW <br>Volvo FTL
Re: (Chilled Man)
For the right rear, do you have to do anything for the emergency brake to get the rotor off. Vaguely remember on VADIS saying something about it...<p>Also, any more review on the DRT rotors? Looking at them for replacements soon...
Re: (Rues R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>Rues R</b> »</i></TD></TR><TR><TD CLASS="quote">Also, any more review on the DRT rotors? Looking at them for replacements soon...</TD></TR></TABLE><p>Me too, they look sweet.
1 - 20 of 26 Posts
