This needs to be a sticky (wheel fitment question)
901 Views 7 Replies 6 Participants Last post by  V50_T5
What is the OEM offset? What wheel, size, width and offset are you currently running? Post em up! (will 8in wide wheels fit?)
1 - 8 of 8 Posts
Re: This needs to be a sticky (tayk47)
5x108mm
I am running 5x108mm 18x8inch Voxx with 40mm offset and
225/40/18 tires
Works like a charm!
Re: This needs to be a sticky (Kallvin22)
Anyone running 8.5 with an et of 40?
Re: This needs to be a sticky (Moofluffen)
I think my Hiros were an ET of 43, and they were 8.5. No problems with rubbing...with 235/35/zr19.
Re: This needs to be a sticky (carreragt7)
Quote, originally posted by carreragt7 »
Were your hiros flush with the fender?
Re: This needs to be a sticky (Vash13)
Yeah, they were pretty flush with the fenders, looked great.
Then my Evolve M10s should be 43 as well then.. the front is pretty much flush.. the back is still little bit more in since the fenders on the rear stick out a bit more than the front fenders
Re: (Vash13)
I'm running Evolve R5s 18 x 8.5 45 mm offset , lowered 1.3" rubbed 235 40 18 eagle F1 a/s , but Falkens / contis are ok... to play it safe, I'm now running 225 40 18s Dunlaps
1 - 8 of 8 Posts
