1 - 20 of 26 Posts
I have watched small cracks develop around the base of the vertical rubber piece within the mount and had it looked at by my dealer's tech the other day. The mount was given a clean bill of health despite these visible cracks (I quote, "<B>it's not broken until its broken</B>" - yeah, thanks buddy). I didn't like this assessment and took a much closer look at the mount today. To my surprise, I found a LARGE open crack along the front inner edge of the opening. The crack was large enough for me to easily slide a pair of locking tweazers through with zero resistance. To those of you who have the same hairline cracks as I do, make sure you crane your neck further (with a flashlight) to see what's going on in the difficult-to-see areas!<p><IMG SRC="http://img391.imageshack.us/img391/1663/dsc02215dz0.jpg" BORDER="0"><p><IMG SRC="http://img391.imageshack.us/img391/6290/dsc02216mc1.jpg" BORDER="0"><p><IMG SRC="http://img391.imageshack.us/img391/6710/dsc02217zm4.jpg" BORDER="0"><p>On a side note, does anyone have an idea what is causing the brown discoloration around the mount (on the metal bracket)?<p>- Tryg
Re: This can't be good... (RainyS60R)
I was elated to purchase a black Evolve bushing on eBay for a good price, only to hear back from the seller who told me he no longer had black and instead offered me blue. <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/frown.gif" BORDER="0"> <p>- Tryg
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>RainyS60R</b> »</i></TD></TR><TR><TD CLASS="quote">I was elated to purchase a black Evolve bushing on eBay for a good price, only to hear back from the seller who told me he no longer had black and instead offered me blue. <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/frown.gif" BORDER="0"> <p>- Tryg</TD></TR></TABLE><p>Also Volvo changed the engine bushings with new ones,you can ask your dealer.I use them and pleased till now.<p>I can't say about Evolve bushings because haven''t used.But don't think that there are so much difference.
The bushing is much thinner at the front and rear. I would be more concerned about the top and bottom of the bushing being cracked. The top mount bushing has been a problem on these cars since the 850 was released in '92.
Re: This can't be good... (xenophobic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>xenophobic</b> »</i></TD></TR><TR><TD CLASS="quote">Also Volvo changed the engine bushings with new ones,you can ask your dealer.I use them and pleased till now.<p>I can't say about Evolve bushings because haven''t used.But don't think that there are so much difference.</TD></TR></TABLE><p>There is a huge difference between stock and something like the powerflex bushing. Huge. <p>Tyrg:<p>If you want a new stock one, bring it back. They'll change it now. Ask to keep the old part (in case you want Evolve, powerflex, etc.)<p>Or just get Evolve, Powerflex now. The removal / installation is EASY. <p>
That's nothing.<br>That probably started within 5K miles.<br>It will take a while before it's cracked completely through. However, this is totally confusing why though they just didn't replace it, they will in another few thousand miles anyway <IMG NAME="icon" SRC="http://www.vwvortex.com/zeroforum_graphics/screwy.gif" BORDER="0">
Call IPD and upgrade <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/biggrin.gif" BORDER="0">
Re: This can't be good... (cloaked)
Yeah, we'll see if I get my eBay funds back in the next few hours... I don't think I want to go with the Evolve blue given what I have heard with regard to vibrations, etc. <p>I assure you all that I am not attempting to open the "which-bushing-should-I-go-with" debate again. <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/rolleyes.gif" BORDER="0"> <p>- Tryg
2021 Inscription Recharge - 2021 Silverado LTZ 6.2L
the discoloration arises due to the heat and gradual decomposition of the bushing.<p>it's radial cracks you need to worry about. ones that make it easier for the pin to move all the way to the mount.
The part of the bushing that your tweezers are going through usually has a very thin piece of rubber which is not critical to the bushing. The part to worry about is the top and bottom where the main bushing contacts the outer ring. Mine was cracked pretty badly on the bottom, and my dealer replaced it with the new square bushing which I like much more than the original stock unit. <p>Shifts are smoother and a bit less vibration makes its way into the cabin. <p>I punched my bushing with a screwdriver in the same spot where your tweezers went through - the rubber in that spot is purely cosmetic.
Hey Tryg-<p>Sandberg told me the same thing about my upper mount with hairline cracks when I was in there last month. "It' ain't broke enough to fix."<p>Likely will be totally failed at about 50,000.1 miles.<p>Kevin
Discussion Starter · #13 ·
Re: This can't be good... (kr900)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>kr900</b> »</i></TD></TR><TR><TD CLASS="quote">Hey Tryg-<p>Sandberg told me the same thing about my upper mount with hairline cracks when I was in there last month. "It' ain't broke enough to fix."<p>Likely will be totally failed at about 50,000.1 miles.<p>Kevin</TD></TR></TABLE><p>That's why I'm defecting to Barrier next week for the next oil change... <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/rolleyes.gif" BORDER="0"> <p>- Tryg
I would agree with the tech. It isn't broken until it's broken. And your's is NOT broken at all.<p>Grendel pretty much hit the nail on the head.<p>You've got an old-style upper engine mount. The area where you pushed your pliers through only has a very thin amount of rubber that is left over from the mold. Unless it is cracked at the very top-center, and/or very bottom-center, it's not broken.<p>An easy way to test if it is broken is to take a screwdriver and pry in between the black metal and the silver metal to see if you can get the black piece to move sideways. If the mount is broken, you'll see it quite easily this way. <p>Nevertheless, if you want to replace it, the Evolve option is a good one.
Discussion Starter · #15 ·
Re: This can't be good... (R Salesman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>R Salesman</b> »</i></TD></TR><TR><TD CLASS="quote"><br>You've got an old-style upper engine mount. The area where you pushed your pliers through only has a very thin amount of rubber that is left over from the mold. Unless it is cracked at the very top-center, and/or very bottom-center, it's not broken.</TD></TR></TABLE><p>Do you mean like this...<p><A HREF="http://forums.swedespeed.com/zerothread?id=59520" TARGET="_blank">http://forums.swedespeed.com/zerothread?id=59520</A><p>The tweezers covered this up in the recent photos - the cracks at the top and bottom are roughly 50% worse than when I typed/photographed the above post. Fortunately, I *just* received my refund from (gulp) Alamo Motorsports for the Evolve bushing they "mysteriously lost" after I purchased it on eBay. I'll be buying a legit black mount from Evolve shortly.<p>- Tryg
That is normal. There shouldn't be any material in that area, only a small film/residu of the moulding process.<br>I do see a small crack in the lower part of the bushing in the 2nd picture but often this starts in the very early stages.<p>Bushing appears to be in reasonable state.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>RainyS60R</b> »</i></TD></TR><TR><TD CLASS="quote">I was elated to purchase a black Evolve bushing on eBay for a good price, only to hear back from the seller who told me he no longer had black and instead offered me blue. <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/frown.gif" BORDER="0"> <p>- Tryg</TD></TR></TABLE>blue should be slightly stiffer, but better for MT, anyway.
Re: This can't be good... (Cicada)
I have freinds who are techs/mgr's at many different dealers and brands. <p>Disclaimer:<br>Now someone may want to get on here and say "I got it all wrong." <br>"I got my head up my arse," etc.. I ain't talking about "What they've seen at this one dealer, blah blah blah.. I'm talking about a tendancy that's industry wide from what I've seen from the inside both working at and later working with dealers while running an independant tuning business. <p>What you have is a dealer is given a tier level that allows them to either pretty much make warranty repairs without question from mfr, ..Or at the opposite end; virtually can't so much as change a light bulb without getting a factory service rep to approve it. What happens most often is dealers have perhaps a service manager that's friendly towards turning work into warranty repairs. (Most often as it should be.) Occasionaly, questionable work also.. but hey, it pays the bills, keeps techs in the money versus sitting around making zilch. (It happens) Although not as lucrative to a dealer personnel as a customer retail job. They get both, a longer rate of pay for job such as 3 hrs versus 1.5.. the advantage is say tech finishes job in 1.25 hrs, he goes on to next job.. hence making more money and a much more profitable hourly scale. i.e. mfr pays out $40 hr versus customer retail of $80 per hour. As you can see this benefits not only tech but mgr's commisison and dealer gross as well, ..and the mfr is not paying out for warranty repair. <B>They ALL win, ...Joe Q customer, is the only one who is much lighter in the wallet. <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/frown.gif" BORDER="0"> </B><p>So anyway, back to friendly service mgr, either owner is greedy and has meeting with mgr and says either increase revenue (ala turn more work into retail and less warranty) or suddenly dealer owner get's a call from mfr saying they are going to change their status, this will of course <B>SLOW DOWN</B> all work orders and hence cause customer disgruntlement and thus bad PR, likely loss of some customers. <br>This will of course draw prompt action from owner/general mgr. Either service mgr will change his persepective, or perhaps change his employment status.<br>(It's a cruel business!! <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/eek.gif" BORDER="0"> ) But that's often how it goes.<p>I sat in a meeting where the owner said, .."sales are down, we expect they will remain down for the next month, service, you need to make $1 million more next month than you have been making to make up for sales."<br>Now how the hell does one virtually double the tickets in one month?<br>(Well, I've explained how that trick get's done. <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/sly.gif" BORDER="0"> )<p>So endsum, from time to time you find good dealers who walk the line between good customer care and dealing with mfr's, occasionally it's very good personnel who make the difference.. who for that reason don't stick around long enough. But I'd bet if you had said, "just replace the mount, I'll pay for it." It would have been done on the spot.<br>Unless, ..they really were swamped or had much more lucrative work to be done. They would in that case though, probably just take your car in and keep it longer. Doing big $$ work first, not changing a mount. <p>That's the nature of the beast
Re: This can't be good... (Dzljet)
Also remember that ALL dealers have a goodwill fund.<br>If you happen to bring your car in towards the end of the month and that fund is either low or still liquid, really can make the difference on whether you get a freebie or a turn down on a questionable (so so) warranty item
While you've got a good grasp of the situation, there's one thing you're leaving out: Quality Control on the warranty process from the manufacturer.<p>Here's how the warranty process actually works from a cash-flow perspective. Customer A brings in his car for a warranty repair X. Dealer performs warranty repair X. Dealer submits to manufacturer said warranty repair, and about two months later, IF the warranty repair is approved by manufacturer, the manufacturer reimburses the dealer. So for every warranty repair done, the dealer is actually out that money until, two months later, they receive reimbursement from the manufacturer.<p>Now, the manufacturer isn't just going to take every warranty submission at face value. They do spot checks. And depending on a retailer's status, it could be anywhere from EVERY warranty repair is reviewed, to 1 in 100, etc. <p>Let's take for example the topic in this thread. The engine mount isn't actually broken. Let's say that, just to be nice, the dealer decides to go ahead and replace that mount under warranty. So they replace the mount, and send the customer on his way. What then happens is, a month later, Volvo asks to see that mount. So the retailer ships it to Volvo. Some Volvo rep looks at the mount and says, "This thing isn't broken! Warranty claim denied." So then a month later, when the retailer is supposed to be getting they're money, they don't.<p>Now, I fully realize that nobody cares about the retailer at all. But let me ask you this: how much business sense does it make to do work for free? From a business perspective, before you do any work, you need to make darn sure you're going to get paid for it, otherwise you won't stay in business.<p>And I know A LOT of you guys complain about how far away your dealer is, blah blah blah . . . well, imagine how much MORE of a pain going to the dealer would be if they went out of business. Just food for thought.
1 - 20 of 26 Posts
