1 - 10 of 10 Posts
These are on tirerack, I entered a 2005 S60 just to see what else was out there for wheels. Very similar to the Atreus for a lot less. $173 for 17"
where'd you get them from? Did you need a hub ring?
Re: (Veefifty T5AWD)
Borbet has other wheels that fit our cars, there really shouldnt be any reason why they (Tirerack) cant hook you up with a set of rings.
SAM also had those wheels on his first C30 before it was wrecked, they look amazingly good http://********************/smile/emthup.gif
Re: (C4L3)
Yeah they are nice, just not sure which finish I like...here's the other option:
On a red car I don't know, I think I like them equally. On my car I think I'd go with the 2nd option, as I don't like the glossy black a lot, if it were a matte color I would like it more. Either way, these wheels are sick and a great deal. What is the weight of each wheel?
Re: (C4L3)
No hub ring needed. Got them here in Belgium at local dealer. 1245 euro incl "dunlop sp sport maxx" tires 225/40/18.
I'd go for the second option under a red car.
Re: (carreragt7)
You can get these Borbet XLs from the tirerack ... in both a 17x 7.5 and 18 x 8 both 45mm offset I believe. They require hubcentric rings but WILL fit guarentied from tirerack (as long as you go with thier recommended sizes)
hmmm... I ran black wheels on a few cars for over 10 yrs... one HUGE benefit is brake dust is the same color.... I like the other finish but thought I'd let you know .
Your car is red? I'd go with the black ones
Re: (V50_T5)
I was assuming because these wheels are indeed offered for different Volvos w/ different hub diameters (as well as several other cars, BMW, OPEL, AUDI etc.) that a "ring" would be necessary???
This is how it USUALLY is with aftermarket wheels
I ran an Evolve wheel this spring w/o a ring and OK I went 300 miles but thought vibrations were too much , took that wheel off and indeed it was missing the ring.
You might ... just NEED a hubcentric ring but don't know it
1 - 10 of 10 Posts
