I'm really curious to see what upcoming XC90 refresh looks like, how it might shoot the gap between current and EX90, and whether both PHEV and non-PHEV get the same treatment. Or perhaps PHEV moves closer to EX90, with milder changes for non-PHEV. Very little speculation online re: what's coming. Lynk 09 might offer some clues.Polyphemus was big and ugly
My guess, one feature they need and should add - a 6.6kw on board charger v. the paltry 3.3kw that takes almost 6 hrs to charge a ER T8. Even a RAV4 prime has a optional 6.6kw. Volvo is falling way behind on that.I'm really curious to see what upcoming XC90 refresh looks like, how it might shoot the gap between current and EX90, and whether both PHEV and non-PHEV get the same treatment. Or perhaps PHEV moves closer to EX90, with milder changes for non-PHEV. Very little speculation online re: what's coming. Lynk 09 might offer some clues.
I'm guessing reveal happens later in winter, perhaps following another dealer meeting in Miami ~Feb? Can't find any such speculation re: meeting or reveal timing.
I’ve read the charger upgrade lands across the range for model year 2024.My guess, one feature they need and should add - a 6.6kw on board charger v. the paltry 3.3kw that takes almost 6 hrs to charge a ER T8. Even a RAV4 prime has a optional 6.6kw. Volvo is falling way behind on that.
I won't buy another Volvo with a 3.xkw charger. If the 6.6kw is actually spec'd in the 2024 I'll be able to wait for it. If not, my $ will likely go elsewhere. A XC60 or 90 with ~34 miles of range and being able to add 5 or 6 miles per hour of charging (I'm basing that on doubling my current 3 miles per hour on household 120v) would mean I would need to buy very, very little gas with our driving pattern.I’ve read the charger upgrade lands across the range for model year 2024.
Yep, that's what I understand is coming...If the 6.6kw is actually spec'd in the 2024 I'll be able to wait for it.
Does 6.6kw translate to ~28 amps? My breakers are 50, so deliver up to 40. Just had a neighbor with new Tesla 3 come over to test new outlets, got 32 amps. But I think he’s got 7.7kw onboard charger.I won't buy another Volvo with a 3.xkw charger. If the 6.6kw is actually spec'd in the 2024 I'll be able to wait for it. If not, my $ will likely go elsewhere. A XC60 or 90 with ~34 miles of range and being able to add 5 or 6 miles per hour of charging (I'm basing that on doubling my current 3 miles per hour on household 120v) would mean I would need to buy very, very little gas with our driving pattern.
Yes (if everything in the circuit, ie wiring, fuses, etc can handle the current).Does 6.6kw translate to ~28 amps?
Is there a reason Volvo wouldn't goal-seek to 32 amps (7.7 kW)? I watched my neighbor's Tesla count to 32 amps and hold there for the duration of his visit. 16-32-40 amps (as 80% of 20-40-50 amps) strike me as more common, by comparison is 27.5 amps kind of random?Yes (if everything in the circuit, ie wiring, fuses, etc can handle the current).
The power (W) formula is current (A) * voltage (V) aka P = i * v.
Assuming v = 240 V and P = 6600 W then i = P / v = 6600 / 240 = 27.5 A.
I believe it was in an Out of Spec Youtube video featuring the then-new 2022 XC60 Extended Range that an engineer from Volvo made a comment about their battery strategy that may give some insight into their use of lower kW chargers. Basically he said that the idea is to provide enough range with an overnight charge to commute to work where you "recharge" the car and then drive home. I've read that the current spec 3.6 kW charger on U.S. household 110/120v, 15/20A current will charge the ER battery in 8 hours or less, certainly fast enough for "overnight". He didn't say anything about the charger, but I can see why the first model years had a low kW charger as they learned about the battery characteristics and longevity. Now, I can't help but wonder if a faster charger portends a larger capacity battery in the 2025 PHEV models? That would be awesome.I've noticed the trend of lower kW chargers on plug in hybrids. Not sure why. I guess the presumption is they don't need the rapid charging capability as they have an engine and so there isn't the need to make sure they can rapidly charge as the battery isn't the only means of propulsion. As PHEVs get larger batteries and greater range (Geely is pushing long range PHEVs as a product now) this seems to swing the need back again for PHEVs to be able to rapid charge to cater to the greatness EV-ness of the product.
I think the reverse has happened, larger battery for MY22.5 portended a faster onboard charger.Now, I can't help but wonder if a faster charger portends a larger capacity battery in the 2025 PHEV models? That would be awesome.
Does anyone know if the global (?) market which killed the XC90 Excellence has significantly changed to signal bringing back an EX90 Excellence?
