1 - 15 of 15 Posts
Moderator
Discussion Starter #1
The suspension is finally done! After 4 months (Weekend work only) I finished swapping out the entire suspension. Everything was replaced with OE/OEM parts except the Subframe bushings and Springs. Hope this helps others in the future.
Generation Volvo Delrin Front Subframe Bushings
Generation Volvo Delrin Rear Subframe Bushings
Volvo Engine Mount - Hutchinson 30778952
Volvo Mount - Hutchinson 30748811
TME S60R Lowering Springs
Monroe 4C Front Struts
Monroe 4C Rear Shock
IPD Rear 25MM Swaybar
985111 Volvo Subframe Mounting Bolt - REPLACE ALL
9492040 Volvo Front Suspension Stabilizer Bar 25MM
31201386 Volvo Strut Mount Washer
30760914 Volvo Strut Bump Stop
30647969 Volvo Strut Mount Cap
30666314 Volvo Coil Spring Insulator
30666850 Volvo Strut Dust Sleeve
30666315 Volvo Coil Spring Insulator
30683637 Volvo Strut Mount Spring Seat
31201602 Volvo Sway Bar Link Lemforder
31201603 Volvo Sway Bar Link Lemforder
30714968 Volvo Strut Mount
8646101 Volvo Shock Absorber Support Plate
30748888 Volvo Spring Seat
31658084 Rear Wheel Hub
31658085 Rear Wheel Hub
31277893 Trailing Arm Front Bushing
9173761 Upper Control Arm Inner Bushing
31277952 Track Bar Bushing
30748437 Lower Control Arm Inner Bushing
31277899 Upper Control Arm Inner Bushing
9200301 Lower Control Arm Outer Bushing
9127363 Trailing Arm Lower Bushing
31277896 Lower Control Arm Link
985870 Lower Control Arm Lock Nut
986931 Track Bar Bolt
30787687 Oil Filter
30759630 Differential Carrier Front Bushing
30774518 Bosch Volvo Leak Detection Pump !!!REPLACE!!!
9186408 Volvo Exhaust System Hanger Rear (S80 S60 V70 XC70 XC90)
30657359 Volvo Exhaust Hanger (For Catalytic Converter)
IMG_0749 by Jp, on Flickr
IMG_1271.HEIC by Jp, on Flickr
IMG_0798 by Jp, on Flickr
IMG_0796 by Jp, on Flickr
IMG_1270.HEIC by Jp, on Flickr
IMG_0797 2 by Jp, on Flickr
IMG_0795 by Jp, on Flickr
Moderator
Discussion Starter #2
The rubber industry thanks you.
Moderator
Discussion Starter #5
It was way overdue, it defintiely rides amazing. Biggest things are smooth/solid feeling and the confidence in flat out corning. It really feels so dialed in and very predictable, which is both a good and a little boring at times.
Moderator
Discussion Starter #7
Nice work, where's the 56k users warning??
Who still uses 56k? I'm getting about 1.2mbs on my phone on the train, haha.
I guess Flickr Stopped auto-scaling reposted links :(
Subscribed. What I plan to tackle in 2020 (except I'll probably not remove the entire subframe). You went with a non-IPD front sway? Any increased NVH with the solid subframe?
Moderator
Discussion Starter #9
I went with a non-IPD because the bushings are fused in and rubber VS poly so a little less vibration. As far as NVH and the Delrins, No and Yes, regular road bumps no but you will feel the more extreme bumps like pot holes a little more. In my opinion, well worth it and my R is probably the most NVH focused of any R out there.
It’s beautiful. Great work and a BIG project. You have a brand new R. I think you now need more challenging corners and hills to satisfy that thirst for burst.
I am doing the same exact thing, but I am using all Powerflex in my rear. I too am going with the Delrans in the front and now the rear after reading your parts list.
I never drove a new VR but now I plan on it, just modified a little.
Nice. How many miles on your R?
Moderator
Discussion Starter #13
127k at the moment, many more to come!
Been looking for rear Delrin rear subframe bushings... Have the fronts installed with the TME springs all-around. Googling "Generation Volvo Delrin Rear Subframe Bushings" always deletes the word "Generation". Please elaborate on sourcing these.
1 - 15 of 15 Posts
