1 - 11 of 11 Posts
In both the S60s I've had the paper holder in the windshield rattled. So if you hear a noise that comes and goes and it appears to be originating from the dashboard or steering wheel, it is probably the paper holder. I placed a small felt pad to avoid it.
Re: The transparent plastic paper holder on the windshield rattles.... (BrunoS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>BrunoS</b> »</i></TD></TR><TR><TD CLASS="quote">In both the S60s I've had the paper holder in the windshield rattled. So if you hear a noise that comes and goes and it appears to be originating from the dashboard or steering wheel, it is probably the paper holder. I placed a small felt pad to avoid it. </TD></TR></TABLE><p>You can use a hairdryer to heat it up a bit and bend it to fit tigher against the windshiled (did that only old 850T wagon, kept it quiet for about a year and then had to do it again). So far has not happened in any of my other Volvos.<p>LTA<br>
Re: The transparent plastic paper holder on the windshield rattles.... (LTA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>LTA</b> »</i></TD></TR><TR><TD CLASS="quote"><p>You can use a hairdryer to heat it up a bit and bend it to fit tighter against the windshield ...</TD></TR></TABLE><p>I did the same thing in both our Volvos. The R's got bent when I was cleaning the windshield and the XC90 happened on it's own. The hairdryer works great and so far I've only done it once to each vehicle.
The ticket holder on my car buzzed when I first got the car, & I quickly got tired of the noise. A clear, stick-on vinyl bumper worked for me & is not noticeable . . . one of the little doodads (maybe 1/4 to 3/8 inch diameter) that you can buy at a hardware store. They are often used on the back side of kitchen cabinet doors.<p> - Mark
Re: The transparent plastic paper holder on the windshield rattles.... (geoguy)
I've heard there is a VADIS software upgrade for this problem. I'll check to see if I can find the number. <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/rolleyes.gif" BORDER="0">
<IMG NAME="icon" SRC="http://********************/smile/emthup.gif" BORDER="0"> <IMG NAME="icon" SRC="http://********************/smile/emthup.gif" BORDER="0"> <IMG NAME="icon" SRC="http://********************/smile/emthup.gif" BORDER="0">
Re: The transparent plastic paper holder on the windshield rattles.... (steamboatsig)
'Within spec' would be better wording...lol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>steamboatsig</b> »</i></TD></TR><TR><TD CLASS="quote">My dealer said the sound was normal....</TD></TR></TABLE><p>He had that ID 10 T problem that many of them have... oh, hell why be cryptic... he's an IDIOT!<p>LTA<br>
Mine would get loose periodically as well, but I always found that simply pulling up (as in toward the headliner, not away from the window) would cause it to click a couple times and get tighter - no padding necessary...<p>d-
1 - 11 of 11 Posts
