1 - 10 of 10 Posts
· Registered
Time to upgrade the CPU to run a new front end with integrated 3-D overlayed MapPoint NAV and many new features integrated over the old DriveSoft system...
Rev. 1.0 (old):
Hardware:
PC
VIA EPIA MII 10000 Motherboard
Opus case/power supply
Audigy 2zs 24bit PCMCIA sound card
Hauppauge PVR-150 MCE (TV/FM tuner)
ATI 256MB PCI Radeon VGA
Etc.:
Xenarc TSV 7" touchscreen
External 1394 slimline DVDRom (glovebox)
External 1394 60GB 2.5" media drive
MacCally combo USB2.0/1394 hub (12V)
XMPCR USB XM tuner with optical output mod. (can use XMDirect)
TripNAV TN-200 USB GPS antenna
MSFT USB->Bluetooth transceiver
NetGear USB 802.11G
Pioneer ND-BC1 backup camera (AV2 on Xenarc)
Alex Peper OBD2 cable/software
LIND 12v voltage regulator shutdown timer
6 circuit marine fuse panel
Volvo 12V accessory outlet
VGA, USB, FireWire extension cables etc.
Software:
XP Pro
DriveSoft media front-end
iGuidance navigation
CyberLink PowerDVD 5 Deluxe
Vehicle Explorer Scan Tool OBDII software
Audio:
Clarion DVH-940 5.1 DSP with DVC-940 controller
JL Amps - 7 channels @ 75 Watts, sub @500
MB Quart satellites 5
DynAudio rear 8"/1" 2 ways
JL 12' Sub
Custom optical cable (Audigy TOSLINK to Clarion Hosiden)
Kimber Kable Tonik RCA interconnects (1 meter)
Replacing the CPU with new motherboard/processor etc.
Rev. 2.0:
Hardware:
iBase MB896 mini-ITX motherboard
120W DC-DC powersupply
Pentium M 1.8 GHz w/2MB cache
1GB DDR2 533 MHz RAM
30 GB Hitachi Endurastar ruggedized drive
Pharos GPS
Software:
XP SP2
MapPoint '04 (NAV)
StreetDeck media frontend
... and an old shot of the screen mount:
... a screen shot of the home screen on the new frontend:
· Registered
Nice setup. What type screen are you using? How in the world did you get Streetdeck already? I didn't think the devloper version was out yet? How do you like it?
I am trying to do something similar with a EPIA MII1000. I've got the screen (touchscreen, vga) popping up from the dash, like the stock navi and am keeping the stock head unit. I'm going to try to do the onstar hack so that I can have optimal GPS/NAV using Iguidance. I'm also going to run Media Engine as I love the look and feel to it. Check out my thread
http://forums.swedespeed.com/zerothread?id=54943
· Registered
Re: (juve021)
Quote, originally posted by juve021 »
The screen is a Xenarc TSV.
I've been part of the Beta since StreetDeck was UbiquityV. Got the first Beta about a year ago and it is vastly improved since then but haven't used in the car yet. Hoping to be able to do an OBD-2 plugin for it for Alex Peper's OBD-2 cable.
Hope to have it in the car this weekend and get the XM/NAV etc. sorted out then start work on the plugin.
I'm interested to see your progress on the pop-up screen. Keep us updated. http://********************/smile/emthup.gif
Wanna buy my copy of iGuidance or do you already have it?
· Registered
Re: (StaggRLee)
Awesome! I've seen the videos on streetdeck, it looks very very nice! I'd love to get a copy of it once it comes out legit and stuff.
I'll keep my post updated on my progress of the project...I'm looking for an indash monitor housing right now and its not looking too good but I've got another plan
Thanks for the offer on iguidance but I recently bought myself a copy. Have anything I might be interested in?
Question though, how much info can you get from the R and OBD? I've heard it varies from car to car and was just curious if/what all the sensored data is available. Thanks.
Modified by juve021 at 9:15 AM 3-17-2006
· Registered
Re: (juve021)
You might be able to mod the chassis and stuff for a G35 screen mount. The same guy who started street deck makes screen mounts for them.
You can get them here: http://www.mp3car.com/store/pr...d=116
All the standard OBD2 stuff: IAT, Fuel Trims, O2 sensor data etc. but can't get boost. You can D/L a demo off Alex's site and play around with it to get an idea of what's available. http://www.obd-2.com/
· Registered
Update:
Got everything (almost) integrated and working but been struggling with the audio side of things.
The Audigy 2ZS PCMCIA isn't going to work in the new motherboard. The Via MB had a PCMCIA slot and the new one doesn't.
I tried to use a PCI->PCMCIA adapter card but the new MB doesn't properly allocate resources.
So I tried an E-MU 0404 "prosumer" card and that didn't work.
Bought a Turtle Beach Montego DDL card but their advertised 24 bit/96 KHz support is bogus. The chip supports it but their drivers/codecs don't.
Creative's X-Fi series needs an optional but not-yet-available digital I/O module to interface to my Clarion Dolby/DTS DSP's optical input. And they don't support Dolby Digital Live on-the-fly 5.1 encoding.
And then I found the Auzentech X-plosion card that has optical digital 24/96 output, DDL and is the first and only card to also support DTS Connect, and beats the X-Fi series in all but game benchmarks of EAX audio, and for less $.
Perfect and everything I want/need -- I hope. It will be here in a day or so. http://********************/smile/emthup.gif
http://www.auzentech.com/products_xplosion.html
Modified by StaggRLee at 11:15 PM 3-20-2006
· Registered
Yeah this is why the VIA boards are so convenient but at the same time I can see how they don't pack the video graphics processing power needed for intense stuff. Good luck with the sound card, hopefully this one will work out. Question, what type of power supply are you using? Opus? And how many watts is it outputting?
· Registered
Re: (juve021)
Update:
Found the source of the problem. iBase changed their PCI design and the Opus riser card wasn't modified to accomodate it. Lower slot has a problem.
Got the sound card but need to get a new riser to be able to use both slots. Should have the upgrade completed this weekend.
Modified by StaggRLee at 7:13 PM 3-23-2006
· Registered
Re: (StaggRLee)
Got the new upgraded CPU installed and working with the Beta Streetdeck front end. Didn't take any screenshots but you can see much better ones than I could do here.
I love the MapPoint NAV interface with zoomable maps, 3D and birdseye views. The "gesture" interface is very nice to have as a safety feature. You just use a series of touchscreen gestures to navigate to the modules, search for albums/artists, or to input address details for NAV routing.
The XM interface is also very nice. In fact the entire program is, I'm very impressed with it.
The X-plosion sound card was pure kismet. It does almost everything I want (besides accept an optical input from my XM tuner -- I need to get their daughter-card for that) and it sounds awesome.
I can now upconvert any two-channel source to Dolby Digital or DTS encoded 5.1 and send it to my Clarion DSP (which accepts both)... and it sounds WAY better than the Dolby ProLogic II that the Clarion upconverted to. Also the card allows direct monitoring of analog input and on-the-fly encoded output to the SPDIF output(s). This card rocks for about $90 shipped (after rebate) from zipzoomfly.com.
Here it is installed:
Modified by StaggRLee at 10:37 AM 3-26-2006
1 - 10 of 10 Posts
