The DEFINITIVE V70 & V70R Subwoofer Installation Thread
14278 Views 75 Replies 18 Participants Last post by  ScottishBrick
10
Title is a bit silly, but I hope to write a pretty detailed/informative post on the subject which includes how to use and convert the '05+ harness to '04- cars, and vice-versa.
COMPATIBILITY: this post focuses mostly on '05+ cars for wiring, install method and parts are the same for both. For '01-04 wiring, see excellent info from @ScottishBrick and @LukeFlynn starting at post# 68 here
For aftermarket sub installs, @NuovoRecord and @vXoCl7v0o have cracked the code to keep the proper factory harness. See post# 37.
Alternately, to avoid wiring a relay circuit for aftermarket installs, @khnitz discovered that tapping fuse #22 in the REM (for an '05+ car) will grant ignition switched power.
PARTS & PRE-REQUISITES: pricing is current (ish) as of 2021
  • Subwoofer assembly: 8648371 or 8633653 - still available from various sites around $500 or so, comes with subwoofer enclosure, amplifier, thumbscrew and bracket.
  • Spare tire anchor, low profile: 9492798 - usually $10-13 - necessary so the subwoofer can sit above spare successfully. If you have a full-size spare, you'll need to get the donut.
  • Carpet if you're crazy like me - 9468705 - available for around $90 or so
  • Use my part search script to save some dough if you're buying stuff!
If you've acquired a sub secondhand without a bracket or thumbscrew, like me, you'll need:
  • this knob, or one with same thread pitch/length/dimensions.
    Star Grip Knob, External Thread, Screw Length 0.78 In, Overall Length 1.57, Thread Size M8 In, Dia 1.26 In, Knob Type Star Grip, L Style, Thermoplastic, Matte Black
  • ...and to either fabricate a bracket, or contact @[email protected] here on Swedespeed, his brother makes phenomenal brackets for an incredibly reasonable price. I've installed two, and they're perfect. That's the bracket we'll be using in this post.
If you aren't pre-wired for the subwoofer, you'll need a harness - I've included the wiring diagram with pinouts and instructions if you want to craft your own harness, but the OEM one is still available from Volvo, and is relatively easy to install with the attached instructions. It also includes all the connectors you need, which would be a little bit of a nightmare to source and/or cut/solder, especially the REM side of things. To check if you're pre-wired, look below the cargo floor, under the lip by the tailgate latch. If you see a connector that looks like this, you're pre-wired.
128851
128852
If not pre-wired, you'll need:
- harness - 9499482 is for 2001-2004 wagons, and is available for ~$90 as of mid 2021.
NOTE: 30730120 is for 2005-2007 wagons, and is NLA as far as I can tell. Except for two power pins, they're identical, and that's easy to fix by removing the large combo power pin and soldering on two smaller pins from an '05+ REM connector if you have a 2005-2007 car. That process is detailed below.
INSTALLATION: Great, you got all the stuff! Let's begin. Follow the attached instructions exactly, read carefully - you don't need to take all the rear tailgate plastics/tailgate lip trim out like I did when installing the harness, but it did make running the cable below a little easier. I'll mostly be covering the parts that aren't covered in the installation manual, like retrofitting the '01-'04 cable for an '05-'07 car, and just lightly touching on everything else. Use the installation PDF mostly.
1. While your cargo floor is out, give 'er a good vacuum and wipedown if stuff spilled over the years.
128853
2. You do need to take the left side panel off, but not the tailgate lip trim. Again, I did, but not strictly necessary.
128854
3. For utilizing an '01-'04 harness in an '01-'04 car, just follow the install instructions, but the single big power pin goes in a different place in the REM than in a later car, get with someone who has VIDA to get the location for that pin, everything else is the same.
4. For using an '01-04 harness in an '05-'07 car, follow these steps.
- I harvested a brown REM connector from a wrecked 2005 car (S60, V70, whatever works - same REM) and harvested two of the pins from spots 1 and 2 - you can check if they're the right size by test-fitting them in the correct spots on the REM connector (pins 17 and 18 as indicated in the installation manual)
128856
- This is the big combo power pin from the '01-'04 harness, we'll be removing this and putting a smaller pin on each of the two wires going into it.
128855
- Here's the two pins I harvested, next to the big combo power pin.
128857
- I then snipped off the big combo power pin, stripped the wires a little bit, and carefully pried apart each individual small pin's fingers to release the wire and make it possible to insert another wire. I then inserted one of the larger diameter wires, crimped it with the fingers of the smaller pin, and soldered it in, taking care to keep the solder low and package size small as to not interfere with the locking mechanism of the pin so it will still snap into the REM connector.
128858
Reactions: 5
1 - 20 of 76 Posts
Nice. Was planning to do a writeup of my own for ‘01-‘04 cars using the ‘05-‘07 harness (which is what I mistakenly bought from the dealer and had to retrofit for ‘04) but didn’t get a chance to take pictures of some steps in the process.
Great overall coverage of what needs to be bought and what needs to be done!
Reactions: 2
9
- Both smaller pins soldered on!
128859
- After the one large pin has been turned into two smaller pins, you can install the harness like normal - connect the speaker leads to the l/r tweeters and run the harness like in the manual.
128860
- pins installed in REM connector, perfect! It's the two above my thumb.
128861
- back view - two red cables are the ones we soldered smaller pins on.
128862
- Button it all up like in the manual! Enjoy your magical factory Volvo sub.
128863
- Finish it off with the carpet if you have more OCD than money.
128864
- Bonus: up-close of the bracket @[email protected]'s brother makes, and the Amazon replacement knob.
128865
128866
AMP NOTES: If your fan is noisy and/or dying, this one fits and is a similar spec for power draw/airflow. I replaced mine as it was noisy.
128867
Additionally, the sub I got had the amp connector for the subwoofer cut off, the subwoofer amp speaker connector is the same as the amp power connector under the front passenger seat, so I picked one of those from a junkyard car and soldered it on. Works great, just verified polarity with an existing/not cut sub.
@JRL for the wiring diagram and sage advice, @R-Pow3R3d for hooking me up with the knob link and more sage advice, @[email protected] for getting me in touch with his brother who made the bracket I used, and @ZZZZZZZ for the inspiration.
Reactions: 4
Nice. Was planning to do a writeup of my own for '01-'04 cars using the '05-'07 harness (which is what I mistakenly bought from the dealer and had to retrofit for '04) but didn't get a chance to take pictures of some steps in the process.
Thanks! I tried to get both halves posted quickly but you beat me to the punch haha
Reactions: 1
Glad I could inspire. Maybe you can help me with mine if I get one? Lol
Reactions: 1
You know it!
Sent from my Pixel 5 using Tapatalk
Excellent write up! I couldn't be happy with my sub installed in my 07 XC70. Followed these instructions to the letter.
Reactions: 1
Nicely done!
Reactions: 1
Quite welcome. Love the knob. It looks like it belongs. :)
Reactions: 1
If you have a pre-wired subwoofer harness (NO sub installed) in the P2 XC70 trunk, how can I confirm the other end is connected to my system and where would it be in that case? (My setup HU850, PA300, Premium)
If it's prewired you're good. Sub harness ties into REM for constant + switched power, and ties into rear tweeters (on d pillars) for l+r audio.
I have looked everywhere and your post is the first one making it clear how it's all connected! Thanks!
So the factory sub amp is connected via speaker cable input, I guess I would need a converter if I need line-level input for a 3-party amp right?
Reactions: 1
Eh, input from sub harness should be pretty clean... Not sure how you would extract line level without tapping into the DIN connector going to the PA-300. Speaking as someone who has the original factory sub, it sounds pretty great. @bencrabtree27 has retrofitted a non-factory amp and I think is pretty happy w/results using output from factory harness
Reactions: 1
I've also done a 3rd party amp install. Used the speaker-level inputs straight from the stock harness.
Reactions: 1
Did you remove the connector on the harness or did you create your own adapter?
No need to create one or hack anything - just grab a radio pigtail kit for an aftermarket stereo on eBay or Amazon or something, same connector.
Something like this...
Can beef up power and ground pins or run directly from battery/chassis since ground is right there by the battery
I cut up my stock harness, but probably go with what tabormeister suggests!
I used a connector for the audio, as tabormeister suggested. This was it, I think: https://www.amazon.com/gp/product/B0002BEVAW/
Power is run directly from the battery.
Reactions: 1
This is a super useful thread, by the way.
One note from when I first installed the stock setup in a 2004 V70 that wasn't pre-wired for a sub: the amp uses ground for the switched power, not +.
Reactions: 1
That's super useful, I had no idea! @bencrabtree27 there's your problem.
Reactions: 1
Would this be possible in a 04 V70 with the rear facing seats?
1 - 20 of 76 Posts
