2006 XC70
Hi All,
I just had my the Four-C shocks on my 2006 XC70 replaced with regular shocks my local garage. However, when I got the car back. the "Text Window" on my dash ( the one that shows warning messages ) was dark. Turning it off and on shows a brief glimmer of a green bar for a moment, but no text shows. The Four-C shocks that were removed still have the wires on them, so they were disconnected at the connectors where the wire from the base of the shock is connected (~ 15 inches up). I don't currently have a VIDA DICE to check codes. The local garage seems to have no idea what happened.
I've had researched the Four-c delete on this and other forums prior to the replacement and I was expecting some error messages to be displayed because of the wiring not be terminated with the solenoids/resistors, but I was not expecting the Information screen to be blank/off.
Any guidance would be greatly appreciated. Thanks. PGM.
Take the old shocks and just plug them in to see if it goes back to normal. May be that something unrelated happened.
2006 XC70
Thanks J5T, very sensible suggestion. I'll give that a try.
Update, after a couple of days driving the car (5 or 6 restarts), the Text Window "magically" came back on. However, it's behavior is intermittent...sometimes it comes on and others it does not. I am wondering if there is something like a ECU diagnostic that runs on start up that might be affecting its behavior. In any case, I will monitor the behavior. I might look at trying to do a delete of the Four-c software configuration and see if that changes thing...I believe I saw that it can be done with VDASH.
