My temperature sensor came loose/broke off from the plastic shield next to the lower air dam. How should it be reconnected?<BR>Pointing into the housing, from the passenger side towards the drivers side? (With the clip on the outside, and the wire on the inside?)<P>Also, the whole shield/housing is quite loose: seems to only be screwed in on the far left and right sides. It rattles/shakes forward and backward pretty easily. Should it snap in somewhere or are some screws missing?<P>Thanks!<P>
