1 - 19 of 19 Posts
I have an '06 S60R. I just noticed my temp gauge is not working. The car feels sluggish under accelleration too. Anyone have similar problems? Any ideas?
IIRC there is a TNN out for that need to pull codes with a volvo reader but i bet it needs a ECM upgrade
Software upgrade should cure the issue.
It's as if the ECM thinks the engine is cold forcing it to burn rich.
We've alerady told you, go to the dealer for a software update. This was a problem with the 06's and there are several threads on the topic.
Amazing there are still Rs running around without the upgrade.
Happened to me 3 (4?) times. A few software upgrades and a new thermostat and I haven't had any problems since.
Plane on ECT / Thermstate first and then software upgrade.
The car wil go into limp mode if the ECT goes bad.
I have seen it on numerous cars.
Has anyone seen this same problem on a 2007 S60R AWD? Mine just started doing the exact same thing, no reading on temp gauge, cooling fan running full out even with a cold engine, poor acceleration, but no Check Engine light.
- Mark
There have been many cases of this here where a simple ECU RESET restored correct operation. My car was one of those cases.
just had this happen with my 06 VR a month or so ago - software update + new thermostat fixed it.
How sluggish are we talking about? Like, "that's a bit slower than I remembered" or "wow, there's something SERIOUSLY wrong here."
I would replace the Thermostat and rest the ecu ........
It will boost but not nearly as much. Power really falls off above 3000 RPM. It's driveable though. I'd say you could do 0-60 in maybe 11-12 seconds.
I'm on my 2nd ECU reset to "cure" this same problem. Will probably take it to the dealer next time it happens assuming it's before my CPO runs out (at 91K now).
1 - 19 of 19 Posts
