So, it seems the steering ratio is 16:2 degrees.
Sent from my Pixel 2 XL using Tapatalk
That doesn't seem right. Steering ratio is usually XX:1. 16:2 doesn't make any sense, since it not in lowest terms, plus 8:1 would be an ungodly quick ratio rack like less than 2 turns lock-to-lock! Based on the european use of (,) where we would use (.) in those specs, I am guessing they are implying 16.2:1 which would make sense, a middling sort of ratio, and consistent with the listed 3 turns lock-to-lock.
