1 - 18 of 18 Posts
So this morning the R decided to randomly throw a "Reduced engine performance" message that went away as quickly as it showed up while coasting downhill. Scanned it with VIDA and there are no codes. So I decided to do some datalogging to see if I could get the issue to come back. I couldn't but I found something interesting. At 5500RPM the car is only making 1700hpa of boost with the atmospheric pressure being 970hpa. That's 10PSI. Should my TCV dutycycle be at 100% at WOT?
I'll do it again and get a graph... Stupidly closed mine.
Is the car tuned? VIDA duty cycle is only what the ECM sends out to the solenoid. If the TCV is old/worn or there is a leak for instance the boost pressure will be lower.
Here's a graph I got.
And of course now the numbers look better now that they're saved :mad:
What gear is that and whats the ambient temp?
2nd and OAT is 70F
Second gear is too short to build boost. Revs go up too fast. Not enough load. Try third better. Or go up a steep hill
IAT? Thats quite low. I just assume that at this temp there isnt more boost needed to produce required torque. Cause thats how this ECU operates
No, that's outside, I didn't log IAT.
I guess I have to find a spot to use 3rd...
I thought the duty cycle for the TCV was the percentage of time it's closed. So at 100%, that would mean you're not bleeding off any boost pressure.*
So at WOT, and not yet at target boost, I think 100% duty cycle is normal.
*I'm probably wrong.
Actually it doesnt allow 100% DC. Max is 99.6% thats just the way ECM software is built. And iirc looking at different files. Stock tune shouldn't see 100% no matter what.
You were logging TCV duty cycle just when it happened? Wow
It was stored on the ECU and looked at by a tuner.
Edit: I should clarify, it was showing that the TCV had hit 100% duty cycle on occasions. Considering my car would boost to 25+psi, I think that was true.
Moral of the story: Don't use an aftermarket solenoid for a TCV.
I agree 100 percent about not using an aftermarket tcv and if you start having boost issues out of no where and are all of a sudden over boosting then under boosting its usually the tcv. I just changed out an ard hd tcv that was maybe a yr and a half old. I in my stock pierburgh type tcv and car ran like a champ again.
1 - 18 of 18 Posts
