1996 Volvo 850 Platinum Wagon, 2002 V70 T5M, 1982 245-SOLD, 2007 V70R- SOLD, 1990 760 Turbo-SOLD
Alrighty, well I am just about finished with my dash pad repair. Thought I would just post my process (which is farrrrr from perfect) but should do the job
I had several cracks along the rear insert pony that goes directly under the windshield, as well as other structural cracks that wind up towards the front of the dash towards the driver. I took the edges of each side of the cracks and roughed them up a bit for adhesion, then cleaned them with alcohol. Then, I pasted my adhesive (in this case, I used a JB plastic weld that seemed to have decent flexibility). I applied a health amount to each side, and then placed them together. I then used a series of clamps to hold the cracks together, and then used a second layer of adhesive over the cracks, which I reinforced slightly with cut up paper clips:
I let this seal and set over night, and when I pick up the pad now, it actually stays somewhat rigid, with just a bit of flex which is preferable.
By far, the hardest part was getting the portion towards the driver right. The spot a lot of people see lifting above their two central air vents is what I’m talking about. For that section, there wasn’t much to be done, other than slab some adhesive on and clamp it to the plastic beneath it. Mine is absolutely not perfect, however I would say it is 70-80% better than it was before
Again, YMMV, but I feel as if this was a decent improvement for under 10 bucks. Just have lots of patience, lots of glue, and lots of clamps.
Next, I will be buying some good leather paint, and will go over the top of the dash and get a good color locked down, then I need to see what kind of “clear coat” or protectant should go over it to seal it down.
