1 - 6 of 6 Posts
2005 Volvo V70R
Question 1: Are the 4-piece tail lamps interchangeable between the 01-04 and the 05-07's? I own an 01 XC70 (bought pre-owned) and really like the crystal lenses on the 05-07's and want to do the conversion if possible?
Question 2: Does anyone know where I can find replacement bulb sockets for the tail lamps?
Reasons of why I'm asking is because I'm having a brake light issue message appear on my dash message center. I've changed out both bulbs and even replaced the sockets with the reverse light ones (sockets are the same). The car does not have an owners manual so I do not know which fuse(s) to check. Is there any other recommendations? I've checked with a few other threads and posts, but did not get any replies...
Direct bolt in replacement
Yes they nolt right in, but make sure you use the newer gaskets as if you try and use the original style, they will leak
Yes the gaskets for the newer style lights, are different, than the ones for the earlier style lights.
1 - 6 of 6 Posts
