Volvo Canada/US states the T6 has a 1500kg towing capacity, yet the UK Volvo site gives a 2000kg towing capacity.
Is this just a difference in safety standards? What could one theoretically pull with an XC60 T6?
Re: T6 Towing capacity. (C70drvr)
Maybe the UK capacity is for the D5??
US capcity is 3300 lbs(guessing thats 1500 kg).
I wouldn't exceed that, usually bad things happen if you do.
Quote, originally posted by C70drvr »
Make: VOLVO
Model: XC60
Variant: D5 2.4 LE
Series: DZ
Year: 2009
Body Type: 4Door WAGON
Doors: 4
Seats: 5
Engine Specifications:
Engine Type: DIESEL TURBO F/INJ
Engine Size: 2.4L
Cylinders: TURBO DIESEL 5
Max. Torque: 400Nm @ 2000rpm
Max. Power: 136kW @ 4000rpm
Power to Weight Ratio: 14.06:1 kW/kg
Bore & Stroke: 81x93.15mm
Compression Ratio: 17.3
Valve Gear: DOHC
Drivetrain Specifications:
Transmission: 6 SP AUTOMATIC GEARTRONIC
Drive Type: ALL WHEEL DRIVE
Final Drive Ratio: 0
Fuel Specifications:
Fuel Type: Diesel
Fuel Tank Capacity: 70L
Fuel Consumption (City): 8.3L/100km
Fuel Consumption (Hwy): Not Provided
Weight & Measurement:
Kerb Weight: 1912kg
Gross Vehicle Weight: 2505kg
Height: 1713mm
Length: 4628mm
Width: 1891mm
Ground Clearance: 220mm
Towing Capacity: Brake(2000kg), Unbrake(750kg)
Steering & Suspension:
Steering Type: RACK & PINION - POWER ASSISTED
Turning Circle: 11.7m
Front Rim Size: 7.5x18
Rear Rim Size: 7.5x18
Front Tyres: 235/60 R18
Rear Tyres: 235/60 R18
Wheel Base: 2774mm
Front Track: 1632mm
Rear Track: 1586mm
Front Brakes: DISC - VENTILATED
Rear Brakes: DISC
Front Suspension: MacPherson strut,Coil Spring,Gas damper,Anti roll bar
Rear Suspension: Multi-link system,Coil Spring,Gas damper,Anti roll bar
Other:
Released Date: 01-Mar-2009
Discontinued Date: Not Provided
Average Kms: 7,000 kms
Valuation Range: Average Dealer Resale Price: $63,200 - $75,840
Service Interval: 12 mths / 15,000 kms
Warranty Period: 36 mths / 999,000 kms
VIN Plate Location: Centre Top Scuttle
Standard New Price: 64450
Country of Origin: SWEDEN
Re: T6 Towing capacity. (GrecianVolvo)
2.4D 1800 kgs
2.4De 1500 kgs
T6 2000 kgs
Dutch sales material.
Re: T6 Towing capacity. (Johann)
Quote, originally posted by Johann »
2.4D 1800 kgs
2.4De 1500 kgs
T6 2000 kgs
The data I posted was of an Australian-specs XC60 D5.
Re: T6 Towing capacity. (GrecianVolvo): Unrelated
Yannis,
I was on Swedespeed some three to four years ago and about to leave Germany coming to the Northern Virginia area and inquiring about local dealers for the Home shipment option. Well, you steered me towards Don Beyer Volvo and Ryan Jones to receive our XC90 T6. Finally, after some years, I'm letting you know that everything worked out like a charm, once the navigation software was converted from European to US specs, and I never thanked you before and wanted to do so now, especially when I saw one of your posts on the XC60 forum.
Thanks again!!!
Re: T6 Towing capacity. (GrecianVolvo): Unrelated (sergjut14)
Quote, originally posted by sergjut14 »
Yannis,
Thanks again!!!
Oh! My pleasure! I am glad everything went as you expected! I always love to read/hear good stories!
Best of luck with your new...XC60!
