1 - 11 of 11 Posts
Re: Swimming with Key Fob!!! (mpdbrown)
I'd still open it up and take out the battery & board. Dry everything off...then let air dry for 1-hour, then put back together.
Take out the battery and back cover. Dunk the whole thing in isopropyl alcohol. Lightly agitate. Remove from alcohol and let dry (preferably over an air vent or in front of a fan). Dry and reinstall battery.
The alcohol will remove the corrosive water from the circuitry.
get that nasty water cleaned out fast!
Ive spilled beer on a CDj (CD DJ machine) It worked for a few more hours, started to get sticky.
It was completely erratic after the night was over, and wouldn't respond the next day.
So get the circuitry clean before it starts hurting.
Re: (chinaonnitrous1)
Does anyone know what holds the top part (key end) to the bottom. There is a screw that is still in there but it does not stay together.
92 240 GL
Re: (mpdbrown)
dont forget to also preheat to 350 degrees and make sure to turn over when golden brown
The alcohol will remove the corrosive water from the circuitry.<<end quote>>
Re: (MancUnited1)
Quote, originally posted by MancUnited1 »
And finish with a raspberry reduction.
LOL, man you guys are good for a laugh!
1 - 11 of 11 Posts
