Re: sways (volvosince16)
bout 95% sure they are the same.
Quote, originally posted by jrgoffin » |
If you have two 25mm sway bars, then you probably have the IPD Track-spec bars. The factory bars are 23.5mm (F) and 21mm (R) on the SR (it's 23.5mm 22mm for the VR). I like just the 25mm rear bar with the stock 23.5mm front bar. Helps keep the under-steer down a bit. |
