Looking at lots of post saying people being told to replace whole sway bar!! That's insane as bushings available cheap.summit racing has a variety,now I have 2005 s60 2.5t where I need the diameter of front swaybar to move forward.just wanted to let you guys know the bushings are out there and end links with poly too.
The problem is that the stock bushings are vulcanized onto the sway bar. You'll have to remove the sway bar to get them off with an angle grinder or something like that.
Unless your sway bar bushings are really trashed (not likely) I don't see the point in messing with the bushings unless you're going to upgrade to a bigger sway bar.
