1 - 20 of 29 Posts
Ok I tried googling this a couple different ways and I couldn't really find what I was looking for. I would really like to swap in an S60R turbo and manifold in to my car, and I know the manifold is pretty much a direct bolt on. What about the turbo?? I remember hearing that the oil lines are slightly different from the T5's but how easy is it to make it work?? Should I run the R injectors also or will my T5 injectors work?? The reason why I'm asking is there is an S60R manifold and turbo on Ebay for about $755 BIN and it seems like a good deal.
Re: Swapping an S60r Turbo in to my T5 (chillidawg)
These are slightly different engines (IIRC bore and stroke is a bit different - T5 has a few fewer cc's), so I think mixing up the injectors could be a problem. Bolting on different turbos is more doable, you'll be increasing turbo boost... the engine can probably handle it but it might shorten the life expectancy a bit.
Re: Swapping an S60r Turbo in to my T5 (CaptainBeowulf)
Yeah but with higher boost you need more spark and fuel right?? That's why I thought swapping to R injectors might be a thought, I think they're only 330cc but I might be off. Anyone know anything about the difference in oil lines?? Thanks for the input
What about the ATP Manifold?? Does anyone know anything about that manifold or is anyone using it. Their website says that you can use like three different sized turbos with it and I'm sure the R turbo would work on it. Here is a link to the manifold on their website.<p><A HREF="http://www.atpturbo.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=ATP-S60-002&Category_Code=V5CYL" TARGET="_blank">http://www.atpturbo.com/Mercha...V5CYL</A><br>
thats for C30 only ....
Re: (volvosince16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>volvosince16</b> »</i></TD></TR><TR><TD CLASS="quote">Don't the 03 or 04 T5's have the kkk24 turbo from the factory?</TD></TR></TABLE><p>2005 and up have the R turbo......but the displacement was also bumped up from 2.3L to 2.4L
TUNE TUNE TUNE TUNE TUNE TUNE.<p>Is the most importatn thing . <p>After that its injectors . <p>Intake , exhuast R mani <p>then your golden <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/wink.gif" BORDER="0">
2007 XC70
You'll have to buy the associated coolant/oil lines from dealer for s60R and I would definitely do the green injectors along with the turbo and get a good tune for it. Also do downpipe while you're in there. T5 blocks are very strong. <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/smile.gif" BORDER="0">
find a k24 tune, then decide if it should be right to buy..<p>i've heard of a few guys putting the k24s on their 850Rs and it worked well...
Re: (Impulse922)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>Impulse922</b> »</i></TD></TR><TR><TD CLASS="quote">find a k24 tune, then decide if it should be right to buy..<p>i've heard of a few guys putting the k24s on their 850Rs and it worked well...</TD></TR></TABLE><p>Personally, I'd be worried about bending a rod with the K24. The 19t is known to bend rods, and the K24 pushes more air than the 19t.<p>If you were relatively conservative with he boost numbers, you should be find. I just don't think the cost of going to a K24 is worth it for the performance you're going to gain. I mean, might as well go with a 28R, or a 30R instead if you are already going to go with a bigger turbo.
2007 XC70
a good tune wont bend rods. ifnt420 (sickass xc70 from taiwan) has a k24 with green injectors on a 2.4t (LPT) motor with stock internals and is pushing 250+ awhp. It was tuned by marco (MTE). Everything will be fine provided a good tune.
Re: (cmurphy2266)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>cmurphy2266</b> »</i></TD></TR><TR><TD CLASS="quote"><p>Personally, I'd be worried about bending a rod with the K24. The 19t is known to bend rods, and the K24 pushes more air than the 19t.<p>If you were relatively conservative with he boost numbers, you should be find. I just don't think the cost of going to a K24 is worth it for the performance you're going to gain. I mean, might as well go with a 28R, or a 30R instead if you are already going to go with a bigger turbo. </TD></TR></TABLE><p>me 7 > me 4.4<p>then there is t5shortblock running a 30r on a stock block v70 t5<p>better safe than sorry, yes, but an 18psi tune would be <I><b>perfect</b></I>
Discussion Starter · #15 ·
Re: (Impulse922)
ATP's website says it has a manifold that will fit a fwd and awd S60. Not sure if there is any modification though but if I were going to do it I would definitely contact them first just to make sure. Here's the link.<p><A HREF="http://www.atpturbo.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=tp&Product_Code=ATP-S60-002&Category_Code=BCS" TARGET="_blank">http://www.atpturbo.com/Mercha...e=BCS</A><br>
Re: (shagginwagon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>shagginwagon</b> »</i></TD></TR><TR><TD CLASS="quote">a good tune wont bend rods. ifnt420 (sickass xc70 from taiwan) has a k24 with green injectors on a 2.4t (LPT) motor with stock internals and is pushing 250+ awhp. It was tuned by marco (MTE). Everything will be fine provided a good tune.</TD></TR></TABLE><p>where do you think I am getting my tune for my XC <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/biggrin.gif" BORDER="0">
2007 XC70
Re: (chillidawg)
<br><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>chillidawg</b> »</i></TD></TR><TR><TD CLASS="quote"> ATP's website says it has a manifold that will fit a fwd and awd S60. Not sure if there is any modification though but if I were going to do it I would definitely contact them first just to make sure.<br></TD></TR></TABLE><p>ATP manifold WILL NOT WORK! Please just believe us <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/biggrin.gif" BORDER="0"> the turbo on c30/s40 is oriented on a completely different axis than P2 cars. If you tried to use the atp manifold, the turbo would end up hitting you're firewall. Just go with the s60R manifold and k24 turbo. If you wanted to bolt on a different turbo ie Garrett you could use anything with a t3 exhaust flange as the flanges are the same size but you'll need the adapter <A HREF="http://www.atpturbo.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=ATP-FLS-051&Category_Code=V5CYL" TARGET="_blank">http://www.atpturbo.com/Mercha...V5CYL</A><br>
2007 XC70
Re: (Chilled Man)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>Chilled Man</b> »</i></TD></TR><TR><TD CLASS="quote"><p>where do you think I am getting my tune for my XC <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/biggrin.gif" BORDER="0"> </TD></TR></TABLE><p>good choice my friend. Lemme know how the tune goes with the manual swap since that's what i'll be doing eventually. Did you get the car to turn over yet?
Re: (shagginwagon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>shagginwagon</b> »</i></TD></TR><TR><TD CLASS="quote"><p><br>ATP manifold WILL NOT WORK! Please just believe us <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/biggrin.gif" BORDER="0"> the turbo on c30/s40 is oriented on a completely different axis than P2 cars. If you tried to use the atp manifold, the turbo would end up hitting you're firewall. Just go with the s60R manifold and k24 turbo. If you wanted to bolt on a different turbo ie Garrett you could use anything with a t3 exhaust flange as the flanges are the same size but you'll need the adapter <A HREF="http://www.atpturbo.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=ATP-FLS-051&Category_Code=V5CYL" TARGET="_blank">http://www.atpturbo.com/Mercha...V5CYL</A><br></TD></TR></TABLE><p>Yeah, but is the link that chillidog supplied above for the ATP manifold, is this a different one than the C30/S40 one? Or does ATP ONLY make one T5 manifold period?<p>If just one, and it's for the C30/S40, I get your point about it not working.
1 - 20 of 29 Posts
