i have new struts shocks and springs that i am going to put on soon and i am just wondering what i should replace while i am doing this ?
Re: suspension upgrade (Danhaggis)
You <B>MUST</B> replace the spring seats and check the metal strut plates for excessive wear inside the middle hole.<br><B>Use any XC90 spring seat</B>, they're thicker and wear better.<p>Always a good time to check everything else up there, the sway bar links, control arm bushings/ball joints and inner and outer tie rod ends
Re: suspension upgrade (JRL)
I second this motion... <IMG NAME="icon" SRC="http://********************/smile/emthup.gif" BORDER="0">
i just had two new control arms put on just upgraded my sway bars and i got the ipd spring seats
Well, you're in good shape, just check your tie rods and you're covered.<p>(I would hope that when the control arms were installed the outer tie rods were checked, they're right next to the control arm)
